building a power house to put a ***** in his place
Old Dec 5, 2005 | 09:42 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
Axle/Gears: 10 bolt, 2.23
Hello all!!! I am building an 88 camaro to whoop the living bee--jesus out of a little **** burning friend of mine........ he has an
85 nissan 300 zx. mods include a dual stage boost controler,
full a/c delete, turbo timer, dual friction clutch (CF), lowering springs, tokico illumina 5-way shocks, roll bar (4-point), big (lol 11" is hardly big right) break kit, hood louvers and a short ram (cold air kind of) with a K&N. and a gutted interior
MY car is an 88 camaro with a 350 (currently being built) with a forged crank, H-beam rods, 30 over hyper pistions(Kieth black) speed pro bearings, seal power rings, aluminum heads, Holley stealth ram and management system, long tubes and true dual pipes(2.5 or 3" not sure yet) , aluminum radiator, aluminum water pump, and a t-5 with a CF dual friciton clutch, 1.25 lowering springs, 5-way tokico illumina shocks, 17" ROH rims with 255 40's out back and 235 45's in front (soon to be 255 all around) and hotchkis subframe connectors. full interior, 12" subs, 760 whatt amp 8 speakers total (4x6s,1" tweets, 6x9s, and the 12s) With air conditioning
he says " well my car is my car is lighter than yours and there is no way u can beet me in a drag or on the road course with such a heavy car......" so i tell him.. "yeah but im gonna be making enough Horse power to cary my fat *** and my "heavy efing car" past u at a high rate of speed no mater where we race....."
and next winter weather im faster than him or not im building a turbo kit that should put me well over 600 horse....... so no real point to this post just wanted to brag a little about my new toys and ill update with some dyno numbers this spring when i get the motor in (in Na trim) and the HSR tuned..... so yeah ill get proof of the masacre that will be his most imbarasing moment at the track in front of his "porche" buddys (just for refference he workes at a high end car dealer and all the mechanics that race porches are his frinds........)
LETTT THA Ace whoooping begin!!!!!!!!!!!!!!!!! in T-minus 1.5-2.5 months
Old Dec 6, 2005 | 11:25 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
why don't you ligthen your car as well?
look in the fabrication board for a thread titled "late night quest for 2800lbs."
also, what cam/heads are you running?
and those KB hypers are going to hate you when you pour on the boost.
Old Dec 6, 2005 | 12:24 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
dude seriously if you're serious about handing him his *** sacrifice the subs and sound system. Sell em and use the money on go fast parts. They weigh ya down and IMO affect performance of the ignition system with an amperage drain.
Old Dec 6, 2005 | 03:37 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
what heads cam are you running? those are the biggest part of a motor build and you left them out lol
They can either get you a 14 second slug or a 10 second monster...
Old Dec 6, 2005 | 04:47 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
the cam sellection is going to be decent for NA but great for turbo.. the pistons are gona be good because of the design of the top ring (it does requier more end gap) so the ring doesnt swell up and cut the top of the piston off...
why the accord??? not dissing u but just gotta ask.. i used to drive a 99 ford conture (totaly against my religion)
Old Dec 7, 2005 | 12:13 AM
mw66nova's Avatar
Engine: 7.0L
sorry to tell you, but the Keith Black (KB) hypereutectic pistons are NOT the piston of choice to run boost on...if you run into any detonation problems you can kiss those bad boys goodbye.
and how does big brakes make you faster? mine has the stock brakes all the way around...drums in the back even...and my 305 probably went faster than you.
Old Dec 7, 2005 | 12:41 AM
mw66nova's Avatar
Engine: 7.0L
hmmm...you would be in a for a VERY rude awaikening with some of the guys around here...and they have stereo systems too...and most of them are on a tighter budget than i am (and that's saying something!)
Old Dec 7, 2005 | 08:37 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: building a power house to put a ***** in his place
Advice.
Leave the 350 for someone elses ride, shoot for at least 400 cubes. Then use your HSR and a centrifugal SC and you will have an unstopable street machine as long as you can keep the transmission and rear end from blowing up.
Old Dec 7, 2005 | 11:21 AM
mw66nova's Avatar
Engine: 7.0L
Originally posted by 84RIceEater
PS ConGrats mw66nova
On a Sweet car u built! i remeber when u had the orange one.
thanks man...the old car was actually red...what would be really cool is if you remember what was before the red car.
Old Dec 7, 2005 | 01:55 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
UghhHhHhHhhh DUnno?
My Guess would be a 66 Nova
Old Dec 7, 2005 | 10:24 PM
carzar252's Avatar
Car: 88 camaro
Transmission: 5 spd
well the brake upgrade is mentioned because i am planning to road race this car not just drag it..... that makes for a longer acceleration before having to break for the corner . going in a streight line really fast is fun but pitching a car into a corner and pulling a full lateral G with out drifting is even more of a rush... just my oppinion.. this is not to say that i dont enjoy a little stop light to stop light action and the ocassional trip to the old drag strip
Old Dec 7, 2005 | 10:50 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I thaught it was funny, you got a great crank and cheap pistons ..
anyhow, if you want to build a blower motor, the forged assembly is a big + , but you'll have to run a lower compression, or add a water/alky injection kit.
I doubt a N/A 7.5/1 motor will be fun to drive ..
How high do you want to rev that engine ?
Do you want a screamer or a torquer ?
(example)
Your short block, with cheap worked up vortecs, the HSR, a XR276HR and a goon tune will give you around 400hp/400+ ft.lb at 6k
would that be enough ?
Old Dec 10, 2005 | 11:56 AM
mw66nova's Avatar
Engine: 7.0L
the KB's are fine for an n/a application...actually, that's kinda what they are designed around.
i'm running a set of H345NP speed pro hyper pistons. i'll be running the 113casting aluminum heads with their 58cc heads it'll be 10:1 c/r. those combined with an XE274H cam will be right around the 390-400hp range. this is a VERY inexpensive build and will make power. while it won't run 10's...it'll be great for a mid 12 second car(or high 11's with the right converter/tranny/gear/weight combo like i have...)
Old Dec 10, 2005 | 12:19 PM
what's the specs on those heads??? about how much do they run?
Old Dec 10, 2005 | 01:29 PM
mw66nova's Avatar
Engine: 7.0L
113 casting aluminum 'vette heads. they came on the 88-91 tpi 350 vettes. they have a 58cc combustion chamber, 1.94/1.5 valves and screw in studs/guide plates from the factory. i picked up a set for $400 shipped. slap some new springs on, make sure you have keeper to guide clearance for the cam, new seals, and i'm ready to rock! you'll have to keep your eye out on ebay and the forsale section of this site and others.
i've seen flow numbers in the 190/160 range at like .500" lift. this is for the stock heads. i'll be keeping mine stock for now due to time/money limitations, but when i have another car, i'll be taking them back off and doing a full blown p/p on them. they flow a ridiculous amount when ported properly.
Old Dec 10, 2005 | 02:11 PM
Hmmm kinda wanted to stay away from aluminum heads, but that sounds kinda like what I'm looking for...I have a .470 lift cam would that be ok?
Old Dec 10, 2005 | 04:12 PM
mw66nova's Avatar
Engine: 7.0L
it'd be just fine.
Old Dec 10, 2005 | 05:38 PM
didn't mean to hijack a thread, how much weight savings are they over cast iron?
Old Dec 10, 2005 | 05:52 PM
mw66nova's Avatar
Engine: 7.0L
it's looking like right around 45lbs.
Old Dec 10, 2005 | 05:57 PM
thank you, so is that the same casting that came on the zz4?
Old Dec 10, 2005 | 07:05 PM
mw66nova's Avatar
Engine: 7.0L
i think...that i'm not TOTALLY postive on...
Old Dec 10, 2005 | 09:09 PM
with a comp magnum 270, edelbrock 1405, holley street dominator intake, with a stock 350 how much more would I gain over 416 heads?
Old Dec 10, 2005 | 10:28 PM
mw66nova's Avatar
Engine: 7.0L
stock for stock? probably a solid 25hp...but in ported form, they will make tons more.
Old Dec 11, 2005 | 10:08 AM
awesome, thanks. Know what i'm gonna look for now. kinda wish they were cast iron, but that's cool now when it's time for a rebuild I can shave the deck down a little and make a screamer.
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
sreZ28
Aug 14, 2015 07:48 PM
