Car wobbles when making sharp turns
Old Dec 10, 2001 | 10:14 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
when making a slow sharp turn my front end wobbles and you can hear the tires slipping as I make the turn. I use to have a friend with the same car 91' Camaro who said it is common. Anyone else experience this?
Old Dec 10, 2001 | 10:18 AM
tpi_roc's Avatar
car wobbles?
Do you still have your front and rear sway bars? And do you have your panhard bar?
It sure as heck aint normal with mine
Mine drives like its on train tracks
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 10, 2001 | 12:14 PM
Damon's Avatar
On a slippery surface this may happen (like a seal-coated driveway, or wet pavement) but on rough clean pavement (like in most parking lots) you shouldn't expereince this.
Worn out front end parts - tie rods, centerlink, idler arm, etc. are the usual cause.
Old Dec 10, 2001 | 04:24 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I have all new front end components excepet tie rods but they are good. It happens when I turn the wheel all the way to one side till it hits the stops. But you have to take the turn real slow to notice it. Could it maybe be something with the steering box?
Old Dec 10, 2001 | 04:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by grafx:
I have all new front end components excepet tie rods but they are good. It happens when I turn the wheel all the way to one side till it hits the stops. But you have to take the turn real slow to notice it. Could it maybe be something with the steering box?</font>
No. Just stop turning like that! You don't need to, you know. And it is not easy on the power steering to pull the wheel sharply to the end of its travel and hold it there.
What happens is that every little bit of rock and dirt under the tire is being forced sideways and the tires simply slips over it in stages, causing the jump, jump you are experiencing.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
