whats the diff? retro fit and oem roller?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
between roller cams whats the difference between retrofit and oem?
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Retrofit is usually for pre 87 blocks that didnt come from the factory with roller provisions. Oem is for a standard factory roller block. You seem to have the oem type.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
OEM block is designed for roller lifters, has the spider web to hold them, and a retainer behind the timing chain (which is different) for the cam. Retrofit has the lifters linked in pairs, and requires a button on the timing chain gear to keep the cam from walking out of the block.....and costs much much more.
Car: '02 Z06
Engine: L33 5.7
oh thats lame about the button, i guess the stock plate that slides over the cam wont fit over the retrofit?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
To bolt it in you need to drill into an oil galley, a few people here have done it and some with not so good end results. Another thing is trying to get a bolt to seat good in suck thin material without breaking it, if the bolt goes in too far youll block the galley which isnt good either.
If the bolt comes out say good bye to oil presssure and if the lifter turns in the bore you just lost yourself a cam and lifter(s)
Car: '02 Z06
Engine: L33 5.7
ok lets imagine, i have an oem roller block (cuz i do) and i wanted to put a retrofit cam into it (dont ask why)
would i be able to use the cam retainer plate? and not use button. also do retrofit cams use standard cam sprocket bolt pattern?
There won't be a groove in the front of the cam for the plate. The retro cam would use the standard bolt pattern.
Edit-the factory roller cam has a tighter bolt pattern b/c of the groove in it for the retainer plate.
Car: '02 Z06
Engine: L33 5.7
thanks lo tec you answered my specific question, mainly thats what i wanted to know. you da man!
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
blackroc68
Sep 1, 2015 08:01 PM
gixxer92
Sep 1, 2015 04:32 PM
