car starts some times? Need Help!!!
Old Dec 13, 2005 | 09:17 AM
da_bears06's Avatar
hello,
i have a 1992 camaro z28 it usually starts no problem, but today when i tried to start it it just clicked, but if i turn key off on off on off on , couple times fast in a row it will turn over but still not start. i tried to change batterys did not help. I belive i hear the fulpump commming on...any got any ideals
thanks
glen
Old Dec 13, 2005 | 09:25 AM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
If it has trouble cranking and its not the battery it could be the starter. Find out where the clicking is coming from, hopefully its the solenoid on the starter. When it does turn over but doesn't run it is missing one of two things, fuel or spark. Hook up a fuel psi gauge and turn the car to acc and see if there is proper pressure. If there is check spark hope this helps.
Old Dec 13, 2005 | 09:30 AM
da_bears06's Avatar
thanks i will check now the car only has 40,000 miles do the fuel pumps go out that quick? Well if you have more suggestins please let me know...also whe i go to start it on the dash it has " rfd rest" light comes on? i belive it is the rfd...but i know the rest part for sure...it blicks 7 times then stays on? any ideals
htanks
glen
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
