tranny removal question
Old Dec 18, 2005 | 01:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
removing a tranny from an engine that has siezed up (broken rod) will that be a problem with the automatics? i forget its been a while, will i have trouble pullint the transmission back? cuz i dont know if i have to unbolt the torque converter as well or if i can leave it attached to the flexplate because theirs no way to crank that engine over.
Old Dec 18, 2005 | 01:14 AM
Vader's Avatar
You can leave the TC attached to the flexplate, but will have to pull the transmission straight back. You may have to coax the trans back past the three detents on the input shaft, pump hub, and stator hub. How you're going to get teh tC off after that is up to you, but I presume the pan will be coming off first.
Carnage photos are always good.
Old Dec 18, 2005 | 01:33 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i have photos u just gotta search
j/k
https://www.thirdgen.org/techbb2/sho...hreadid=333136
ill be nice since u helped me.
im sure i can get the torque converter unbolted once i pulled the engine, when u say i will have to pull the tranny straight back past the three detents on the input shaft, pump hub, and stator hub. this sounds difficult, does this mean i will have to be rotating the tranny side to side? i dunno if i can accomplish that.
Old Dec 18, 2005 | 09:30 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Take the trans cross member, tq arm and driveshaft out. Put a jack under the trans pan and let it hang 4 inches or so down. (drain the trans fisrt). Then as your pulling the engine wiggle it and the tq converter will come out too. Of course you need to replace the input seal on the trans if you do it this way. Some people would just take them out togather but you need to get a real good angle to do this and most DIYer's dont have a cherry picker big enough for that. Of course if you do have the engine oil pan off and the heads you can usually get the bent/broken rods out and the engine will rotate.
Old Dec 18, 2005 | 11:56 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sounds like it would be easier if i can just get this rod out...
Old Dec 18, 2005 | 08:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Motor dead, removing tranny from motor anyways, sounds like alot of work from the underside .... why not just pull the motor and tranny as a whole unit, then attach tranny to new motor and reinstall as a whole unit? Then, everything is done from topside (better than being on your back) and tranny is easy removal from motor once the whole thing is out.
Anyways, it's a thought - when I swapped in a 350, I just took motor tranny out as a combo to make life easy.
Old Dec 21, 2005 | 03:00 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
aprox how much does the front have to be liefted to remove the tranny and engine as one unit, i have never done this before. does the crossmember need to be removed?
Old Dec 22, 2005 | 02:37 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
you won't have to lift the car much, ramps under the wheels would be enough
you can leave the K-member up front in, but i'd pull the trans crossmember so when the tailshaft of the tranny got past it the thing wouldn't drop (probably about six inches) and swing forward, maybe smashing something.
its pretty easy pulling it as a unit. pull the distributor, sometimes they smack the firewall.
Old Dec 22, 2005 | 02:38 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
theirs nothing but a block in the bay at this moment, lol
no heads or anything.
Old Jan 4, 2006 | 05:05 AM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
wow saw those pics of the motor i did that to a 4 cylinder ranger onceon the highway! piston had a whole right through the middle! well, you could tell when you put the pieces of the piston together. ruint the heads , cam but the block was salvagable! good luck
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
