lt1 cam vs l98 cam
Old Dec 18, 2005 | 03:11 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
lt1 cam vs l98 cam
i DID a search and cant find any thing on the cams so I'm going to ask what do u guys think? i have an l98 cam i heard it has good and bad. so what is going to be the biggest gane the l98 cam or the lt1 i got a 305 tbi with a 5 speed so let me know and one More the best place to get rear end gears I'm looking for 3.73
Old Dec 22, 2005 | 09:43 PM
84zeddd's Avatar
I heard ZZ4 cams are cheap on E-Bay.It would be a much better
choice.
Old Dec 23, 2005 | 12:54 AM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
I have one, works great! and you can hear it rawr
Old Dec 23, 2005 | 01:38 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The LT1 and L98 cams have approx the same duration (depending on year) but the LT1 cam has more lift. Both versions will fit with the stock heads and valve springs. The ZZ4 cam has too much lift and will not work unless you get new springs and possibly machine work to the valve guides, too.
Old Dec 23, 2005 | 07:20 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree. Stick with an LT1 cam. They are cheap and easier to find than an L98 cam. The ZZ4 cam will require you to machine your valve guides to accept that lift. You would also want to upgrade to screw in studs and do some port work because that cam would be limited with the stock 187 heads.
The LT1 cam is a great choice. It is easy to RPOM tune and has great manors on the street.
Old Dec 23, 2005 | 10:43 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I agree with Shifty. I went with the L98 cam and wish I had gone with the LT1 cam. The L98 cam I chose was way too mild.
Old Dec 24, 2005 | 01:06 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I see you also asked about where to buy a set of gears. I recommend Randys Ring and Pinion.
http://www.randysringandpinion.com/
They have good prices, good parts and good service. I recommend the Yukon gear sets they sell. They are a good gear that isnt noisy at all (my only recommendation is buy a seperate solid pinion spacer rather than using the supplied crush sleeve - failed on me and ruined a set of gears).
Old Dec 24, 2005 | 07:16 AM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Yeah, get the LT1 cam, but go ahead and do the H-11 Tool steel springs, I did at 200k, well worth the $$$. Also, on the LT1 cams the dowel pin in the front of the cam will have to be shortened as well. In the LT1 the dowel pins is longer in order to engage the water pump. But its no big deal. I have the LT1 cam in my car with 1.6 rr's and the H-11 springs now for 66k miles and all is well.
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
