Car Cranking but will not start. Need help only car!
Old Dec 19, 2005 | 11:15 AM
jcampbelljac_88's Avatar
Car: 92 camaro RS
Engine: 305 TBI
I have a 92 Camaro RS it will crank but will not start. I am having the coil tested here in just a minute. After that I am just not sure what i will do. It is also really cold here. All help is greatly app. this is currently my only car need to get it fixed ASAP!!! thanks.
Old Dec 19, 2005 | 12:02 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Are you getting spark and are you getting fuel you can see by spraying crab cleaner in the throttle body if it turns on for a little while your getting spark but no fuel if not your probly not getting spark.
Old Dec 19, 2005 | 12:53 PM
What happened right before this started?
Did you drive it home last night and park it, and ot won't start this morning?
Have you been working on it?
Old Dec 19, 2005 | 01:32 PM
Car: 92 camaro RS
Engine: 305 TBI
I started it and move up from the street to the driveway it started fine. I loaded some stuff into the car went to leave and it would not start. I have changed the distributor cap, rotor, plugs and plug wires.
P.S. That was the first start of the day. thank you for all the help in advance. triing to find me a second body to help check for spark. I am pretty sure that i am getting gas. it was parked over night before this happend. every now and then it would idle a little rough until it warmed up then it would run fine. I just figured it was because it was cold but now i am starting to wonder. thanks again for the help in advance.
Old Dec 20, 2005 | 06:33 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Spray starting fluid into the T.B.I. unit and crank it over. If it starts, you have probably lost the fuel pump. If it doesn't start, check the wiring going to the ignition module to make sure it isn't frayed, rotted, ect. If that all checks out, have a buddy crank it while you check for spark. I'm gonna take a stab in the dark and say that I suspect your ignition module has gave up the ghost, but it's better to chase it backwards rather than throw money at parts you don't need.
Old Jan 20, 2011 | 08:07 PM
pv2johnson's Avatar
Car: 92 camaro t-tops
Engine: 305 tbi
Transmission: auto
Axle/Gears: stock
Re: Car Cranking but will not start. Need help only car!
please guys i have this exact problem ive already replaced the cap and rotor i have an msd distributor with an eccel cap and rotor so in or for me to replace the module ill need to just get a whole new distributor im getting spark fuel and air i dont know what else to do ive tried starting fluid also
Old Jan 20, 2011 | 08:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
And what did it do?
how do you know?
what tests did you do?
Old Jan 21, 2011 | 04:28 PM
pv2johnson's Avatar
Engine: 305 tbi
Transmission: auto
Axle/Gears: stock
i see the fuel coming in there is nothing obstructing the air coming in and i checked to see if there is spark im getting all
Old Jan 21, 2011 | 04:30 PM
pv2johnson's Avatar
Engine: 305 tbi
Transmission: auto
Axle/Gears: stock
it didnt do anything different when i spray in the starting fluid
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
gwade12
Aug 8, 2015 08:17 AM
