Damn lug nuts
Old Dec 20, 2005 | 01:53 PM
Zero's Avatar
Car: 1988 Camaro
Engine: 5.7 liter motor
Transmission: Four speed automatic
Damn lug nuts
When I bought my 89' iroc-z it came with these star shape lug nuts, but with no key. The local tire shops can't do anything. Any suggestions???
Old Dec 20, 2005 | 01:59 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Autozone sells a special socket for removing them.
Old Dec 20, 2005 | 02:32 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
dude.................
find a socket that is close to the same size (preferably an impact socket, not chromoly) and hammer that effer on there
then crank away
i've even ground a bit around the edges before, so i could get a smaller socket on there because i only had good sockets in the right size that i didnt want to mutilate.
the **** will take like 5 minutes a wheel.
supplies needed:
close fitting socket
big hammer
a pipe (to put over your ratchet for torque, if you have stock rims, it will save your knuckles)
30 minutes of time
Old Dec 20, 2005 | 03:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i hate to be the guy to say to do a damn search buuut...
in anycase, either pound a existing socket on, or goto the autoparts store, any good store, and get a removal socket.
its a socket that has tapered spiral "teeth".. you pound it on with a hammer, then turn it loose.. it cuts in as it turns.
it WILL distroy the lock.... but it will get it off.
Old Dec 22, 2005 | 12:02 AM
tad1214's Avatar
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Impact chisel with a V style tip is what we use for the really hard to get off ones at my work. BE CAREFUL!!!! We had a newbie not know what he was doing and ****ed up some guys wheel.
Old Dec 22, 2005 | 02:43 AM
Car: 92 RS
Engine: a slow one
^I've done that too, but sometimes the going gets slow when you're worried about your wheel and you don't have a very good compressor
Old Dec 22, 2005 | 08:41 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
how do you get it off with the chisel? are you trying to cut in then rotate it? or are you actually splitting the lock?
im curious, ive never dried it.... is it easier then the pound on a socket method?
edit:
i have a basicly brand new imact chisel, that ive never used.. lol. i havent had a use for it yet.
Old Dec 22, 2005 | 11:38 PM
tad1214's Avatar
Car: 1983 T/A
baisically you go into it a little bit to make a notch, then you go at an angle to rotate it off. Keep going in the direction (lefty-loosey guys :-D ) till it gets loose, then you usually can do it by hand or vice grips. Anyways, much more consistant than the socket method plus you dont chance wrecking a socket but as I said before... BE CAREFUL!!!! slow is better, slipping = very bad and costly mistake. I like it, I have a el cheapo coleman (the lantern company makes air tools somehow) impact chisel, works like a charm. THe more powerful ones are kind of harder, more vibration so it walks more. But it always works, Only 1 time had it fail, that was because we actually broke the stud trying to get it off it was so rusted on. Impact chisels are great for breaking things too... :-) I like to use it to get the bushings out when aligning a 4x4 truck. Also for just ****ing around too.
Old Dec 22, 2005 | 11:42 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Hammers & chisels you guys are nuts. Go to autozone spend $7 and have them off in 5 minutes.
Old Dec 23, 2005 | 02:13 AM
tad1214's Avatar
Car: 1983 T/A
we have those "universal" sets and they rarely work. that is why the air chisel is sweet.
Old Dec 23, 2005 | 12:54 PM
Zero's Avatar
Car: 1988 Camaro
I went to autozone and they tell me that they have no tool for removing those damn lug nuts! Anybody have a picture of the tool or something? I don't think the guys who work have any clue what their doing cuz every week there's new people and they always have the now hiring sign up!!!
Old Dec 23, 2005 | 02:02 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
I just bought a set of impact flip sockets with lock removal tool on the other side of each size. I remove these things on a weekly basis at work.
Tip try a larger size socket like disturbed said but 6 point impact (black ones) Beat it on with large hammer than impact it off.
Wrenching it off will suck
Old Dec 23, 2005 | 07:25 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i think what your looking of are these,..
http://www.kentool.com/tireserv_WCLM.htm
http://www.toolprice.com/product/7134F
http://www.eastwoodco.com/shopping/p...&keyword=43691
there are some listed on ebay too.
with the manufacturer name & part number you may be able to get it from autozone
Old Dec 23, 2005 | 08:00 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Will the same thing be able to take the lcoking nuts off my RS wheels? They are different than the ones in the original post. Mine have little notches on the othside diameter of the lug nut.
Old Dec 24, 2005 | 12:11 AM
DENN_SHAH's Avatar
90CamaroTBI, i believe they will work for your locks too.
Old Dec 24, 2005 | 12:30 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If you don't won't to use your own sockets, your local pawn shop should have the sockets you need by the dozen, and cheap.
gta892000
Aug 11, 2019 11:16 AM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Fox118
Sep 12, 2015 09:29 PM
fasteddi
Sep 10, 2015 09:32 AM
