pushrod length vs valve length
Old Dec 21, 2005 | 03:51 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i found out my valves in my heads are .100 longer then stock, what causes valves to be needing to be longer then stock? and if its just a case of fitment for springs or whatever, then does that usually indicate the pushrods are gonna need to be aprox .100 shorter then stock? i do know i gotta check with a measurement tool i just wanna be sure i know the basic facts.
Old Dec 21, 2005 | 07:58 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Sometimes it will allow a bit more lift (area for air to flow through) if springs allow it and there is no bottoming of the retainer. Other times guys want to run a taller/more agressive cam profile which needs to have a taller sp[ring to thwart coil bind so a longer valve is used combined with a taller/heavier spring rate to allow more valve travel and thus allowing more air through.
Everything will hinge on the complete valvetrain set-up/components for proper geometry. One cannot assume "I have a .100 longer valve so I need a .100 shorter pushrod" checking is the only way to see what you need.
Old Dec 21, 2005 | 12:08 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i know checking is the only way, but it makes sense right a longer valve means your probably gonna need a shorter pushrod.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
slowsi
Oct 18, 2015 08:49 PM
Scorched1984
Sep 15, 2015 03:42 PM
