I hope it's the oil! Need another opinon.
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Earlier today I was driving to school when I heard this ticking noise. At first I thought it was my exhaust pipes ratteling. I then looked at my oil pressure and realized that it was at 30psi. I just put a new 350 in and it usually is at 60psi+.<P>I dropped the car into neutral and pulled off the highway. That's when I started to feel the engine start to get ready to seize. Right then I shut off the engine and watched the smoke rise.<P>Ok, drama aside, I look under the hood and realize that the oil is really low but when I tryed to crank it, it turned over but struggled real bad. Almost sounded like my battery was dying. I put in a quart of 10w-30 which I had nearby but it didn't fix anything.<P>So my question is this: Is my engine toast? Could it of been something else besides the oil and if it is the oil do I just fill it back up and start the car? <b><center>Thanks for the help!</B></center>
Car: 1982 Trans Am
Engine: 350 4BBL
It wasn't coolent smoke (i've had an engine seize on me for overheating). It was definitly oil smoke, it has that smell. Also there was no fluids sprayed under the hood.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Where was the smoke coming from? What RPM did you have 30 psi oil pressure at? Have you checked the oil level and/or topped it off? Have you verified the pressure with a mechanical gauge?
Car: 1982 Trans Am
Engine: 350 4BBL
The smoke came out of the passenger valve cover (I don't have a breather on it). The rpm was probably around 3000 when the I realized the pressure dropped. I put oil in it today and got the engine to run but it makes this horrible clanking sound. What do could that noise be?
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Yeah, same **** happend to my buddy, he had a hole in his oil pan, somethin went and knocked a pretty small hole in the pan, should check yours.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
