Freeze Plug came out!
Old Dec 23, 2005 | 08:21 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
How do you change a freeze plug, it is on the drivers side front of block, behind the accessories. thanks
Old Dec 23, 2005 | 08:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not much to it. Pull the old one out, drive the new one in.
Old Dec 23, 2005 | 08:36 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Thats it, Ive always liked to put a bit of RTV on my freeze plugs before I install them.
Old Dec 23, 2005 | 08:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I use RTV too. It's not strictly necessary, but it doesn't hurt.
Old Dec 23, 2005 | 09:51 PM
Vader's Avatar
Get a brass plug if you can. No worries about rust through. As long as you're pulling one side, you may want to peek at the others for signs of corrosion and potential leakage.
You're lucky it's in the front. The pair in front of the flywheel are no fun. You should be looking for 1-5/8" plugs (Dorman 565-030).
Old Dec 24, 2005 | 12:16 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
whats the proper way to get it in, i can seem to get it to start. thanks
Old Dec 24, 2005 | 12:53 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
realy isn't much of a proper way and i'm not sure where the freeze plug that you are deeling with is at but, a thin chunk of wood to produce all the pressure over the whole body of the core plug and a slight tap of a hammer should drive it in. Make sure the core plug hole in the block is clean first of course, Take some sand paper to it and clean it as best you can. Then tap away till you get it in. Just be careful if it's brass it'll bend easy i'm sure.
Old Dec 24, 2005 | 01:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A socket big enough to fit inside the cup with about 1/16" clearance all around works well.
Old Dec 24, 2005 | 01:37 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
every time i try to tap it, one side will pop out, and if i try to really hyit it good, the whole thing just pops out. thanks for the help gus, i really appreciate it.
Old Dec 24, 2005 | 01:51 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
must be a big bur on it or such. Look at the hole closer and take a dremel to it if it's burred badly and you have room.
Old Dec 24, 2005 | 02:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just keep trying. They're supposed to be tight, that's what keeps them from leaking and falling out.
Old Dec 24, 2005 | 04:15 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
If your lucky you might find somebody with an installer for them. I bought a kit after messing with one on a thunderbird. PITA using a socket and hammer.
Old Dec 25, 2005 | 02:09 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
yea, i just got pissed and went and bought a rubber one
Old Dec 25, 2005 | 09:08 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
oooh rubber 1 will work for a while but, not half *** long as factory plugs good luck though (i did the same for my pickup because, i was lazy and selling it hehe).
Old Dec 27, 2005 | 08:43 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Freeze Plug came out!
I thought the easiest way was with a torch. Heat it up, then pour water or oil on it and it should slide out.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
