codes dont flash
Old Dec 23, 2005 | 09:33 PM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
codes dont flash
OK i know how to pull codes paper clip style but when i put in the liitle tool from auto zone turn the key foward ( not starting the car) and it stays on it does not flash at all it stays solid??? PLease help me something is wrong with my car but i can not get the codes to help me find out but like i said it stays solid. it happend when a wire burned on my passenger side manifold i got a new computer thinking maybe i fried it when the wire burned no help so since then the car doesnt run as well the check engine light stays on constantly please help me fix the camaro oh by the way its a 83 2.8 carbd thanks in advace
Old Dec 23, 2005 | 10:00 PM
Vader's Avatar
It sounds like you have poor connection, or you may have ECM/wiring damage.
Watch the "Check Engine" lamp closely when you turn on the ignition (with no jumper in the ALDL). It should turn on for about ¼ second, turn off for about ¼ second, then turn back on and remain on. Does the lamp do this?
Old Dec 24, 2005 | 07:46 AM
RST89's Avatar
Car: 1983 camaro
Ok i went out this morning to take a look at that, with no jumper in the adli turned the keyfoward check engine light on started the car there was no change in the light at all with exception of a slight dim from cranking the car over, but definatly no blinking. Thanks for the help thus far what should i do next???
Old Dec 24, 2005 | 08:49 AM
Vader's Avatar
Before cranking, just turn the ignition on. The lamp should "bounce" once then. You should also hear the MC solenoid in the carb cycling, I believe.
Old Dec 24, 2005 | 09:11 AM
RST89's Avatar
Car: 1983 camaro
yeah all that happens the light comes on with the keyfoward then i start the car it doesnt flash or anything it stays solid from the time i turn the keyfoward start it and cut it back off. If you are online alot i really wanna get this fixed. Try to im me also, camaro79350 yahoo and aim thanks in advance
Old Dec 29, 2005 | 08:12 PM
RST89's Avatar
Car: 1983 camaro
ttt still not able to get any codes please help me
Old Dec 29, 2005 | 09:10 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You should get code 12 as a self diagnostic for the computor when you jumper the ALDL.It always begins with this code and ends with it.I would do what Vader suggested and check all your connections/wiring/grounds.Corrosion/moisture can get into the connections and play havoc with it.Also when you swapped out your computor did you reuse your chip or the one it had in it?What was she doing when you started having problems?
Old Dec 29, 2005 | 10:33 PM
Vader's Avatar
If the SES lamp does not do the little ¼-second flash when the ignition is turned on (without cranking - Just the ignition), the ECM may have problems. Start by checking and re-seating the connectors at the ECM (battery disconnected). If that doesn't help, you may have to open the ECM and check the MEMCAL/CALPAK adapter and connections.
Old Jan 5, 2006 | 07:15 AM
RST89's Avatar
Car: 1983 camaro
When i swaped the computer i used the same chip.... When i started having problems it began with the wire that melted on my manifold and threw my ces light oni couldnt get any codes or anything so i went and got a new computer but still same problem it gets bad gas mileage and deisles of those are really the problems and of course the check engine light wont go off and i dont knwo if there are more problems either.
I will check all the connections as for the MEMCAL/CALPAK is that the chip or something else?? thanks for all the elp thus far i put so much into the darn car new engine tranny carb computer nick nacks here and there and i wann get this over with so i can finish her if you know what i mean thanks guys ill let you know what happens
Old Jan 5, 2006 | 08:55 AM
Vader's Avatar
Check the connections on this, both the top side and underside:
You may end up having to resolder some connections or intall a socket:
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
