Adjusting fuel pressure on Mallory regulator?
Car: '86 Camaro SC
Hi, I've got a Mallory regulator on my car and I want to up the fuel pressure a bit. I'm running about 4.5 psi. at idle right now on a carbed SB, NA. Does that seem okay? I thought it seemed a little low.
Anyways, I have a Mallory regulator on the car. It's mounted to the inside of my fender. It has a steel braided line going into it from the tank, a rubber line going out of it (most likely the return line) and a line going to the carb. There's an allen screw on top of the regulator. I went to turn that, but I can't get it to budge, it felt like I'd break of strip something if I tried to turn any harder. Am I adjusting the right screw? If not, which one do I adjust?
Car: check
Engine: check
Transmission: check
Most (some?) regulators have a lock nut. Check for that on the adjusting screw, if there loosen it a little to turn the adjuster. Then snug it down to lock the setting.
RBob.
RBob.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Adjusting fuel pressure on Mallory regulator?
do NOT go over 6PSI...
really, theres no reason for you to adjust it now. carbs do not use a high pressure fuel system.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Originally posted by 305sbc
You have to first loosen the locking nut around the adjuster screw.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup. Loosten the jam nut, set it with the big adjustment screw, then retighten the jam nut down.
http://go.mrgasket.com/pdf/4309.pdf
Car: 1986 Irocz
Axle/Gears: 3.25:1
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
