engine part matching
Old Dec 30, 2005 | 08:34 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
This is a double post from the tbi page also but, after posting there i figured that this may be the better place. If this is a big no no or someone has a problem with it feel free to delete 1 of them.
Alright guys what i've got here is a stock 1986 lg4 block with barely any miles on it (less than 38k on it). What i plan on is a comp cams full install kit with match parts and a head porting.
The heads are 416s and i've already began to grind at them a little. As for cam selection i'm thinking either the comp cams xe262 or xe256 leaning towards the 262.
I'm probably going to leave stock valves in the head and just have a 3 angle valve job done (1.84/1.5s).
I'd like to run headman elite longtube headers( 1 5/8 primarys and 3 in outlets) on it and a weiand stealth dual plane intake underneath the tb (not sure if i'm going to have hood clearance issues so any insight to that is appreciated). I'll have a 454 tb on top of the intake with adjustable fpr and a 255 walbro pump in the tank.
My biggest concern right now is to get the compression up a little, this block already uses the stock thin steel shim gasket so a thinner gasket won't help much, so i'm looking more along the lines of decking the heads (don't want to buy pistons no matter what). What i want to know is the max safe ammount i can shave off these heads?
How high can i safely rev this stock 2 bolt 305 with screw in studs in the head? I'm hoping for 5,500.
I'd also like to know if the comp cams xe262 or xe256 would be fine running a low 9 to 1 compression ratio. or high 8 to 1 compressions (8.8 8.9 or so).
Basically i'd just like to know if this is a good matching setup for a mild build.
Any insight on a better cam selection, intake manifold,hood clearance, cheap ways to gain an ideal compression for this setup are greatly appreciated.
__________________
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
1nastygta
Aug 8, 2015 07:38 PM
