92 305 stalling
Old Jan 7, 2006 | 03:26 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: really need a 5 speed
92 305 stalling
I am having some issues. I was driving on the freeway doing about 80 when the car dogs out and dies. I pulled over to the side of the freeway, tried to start the car and it would stall. I have replaced fuel filter, injectors, plugs, wires cap, and rotor. Fuel pump is working fine. Any ideas would be great.(Tried to search for the answer, but came up with nothing.
Old Jan 7, 2006 | 06:30 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
anybody?
Old Jan 7, 2006 | 06:40 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
I dunno man maybe its the computer or something in the ignition side maybe the coil (but it would not even start if it was the coil)...
Old Jan 7, 2006 | 06:45 PM
baymarauder's Avatar
Car: '92 Camaro RS - gone
Engine: 305 TBI
We might be having a similar problem. Can you keep your car running in neutral by opening the throttle? If so does it make any power? And by "any" I really do mean ANY. My car idles in neutral and starts fine but is completley powerless.
Old Jan 7, 2006 | 06:53 PM
gatoRS92's Avatar
Car: '92 Camaro RS
Engine: LO3
Axle/Gears: 2.73 open diff
Possibly the sending unit? You say that the car would stall. Do you mean it tried to start but couldn't, or it would run and then stall?
Old Jan 7, 2006 | 07:59 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Car would start up, get to about 1000 rpm then stall. Replaced MAP sensor, iac, both injectors, fuel filter and I am running out of money.
Old Jan 7, 2006 | 08:01 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Does not stay started in neutral. Forgot to add that sometimes when I step on the gas pedal, a four foot flame shoots out of the the TBI unit.
Old Jan 7, 2006 | 08:22 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Well you need to esablish if its a electrical problem or fuel problem. Then proceed on trouble shooting.
Old Jan 7, 2006 | 08:27 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
yep it's the 2 basics of trouble shooting a non running or barely running engine, either not getting for or spark or at least not adequate fuel or spark (this is a generalization so to speak but, you get the idea).
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Any suggestions on where to start?
Old Jan 7, 2006 | 08:43 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
woah 4 ft flame realy? That's a biggin (should put some zoomys on that **** hehe).
Well pull your spark plugs and stickem to something metalto see if they generate a spark if not you'll know it's ignition related. (btw don't use the engine itself on a efi setup could possibly fry stuff i would suspest).
If that doesn't do anything for you then, buy a fuel pressure gauge and check your pressure at the regulater.
Old Jan 7, 2006 | 09:20 PM
CF86SC's Avatar
Car: 1986 SC Camaro
Engine: 5.0
check the cat converter what sounds like to me
Old Jan 7, 2006 | 09:24 PM
CF86SC's Avatar
Car: 1986 SC Camaro
Engine: 5.0
sorry for double post if your not makin any power take exaust off fromthe fronmt of the cat then take it for a spin round the block if it does better then ya know what to do to many folks i have seen would junk their cars cause of cat bein stopped up and think it is something more serious then that
Old Jan 8, 2006 | 12:49 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Update: Cat is in good condition. Now car will not even start. I give up.
Old Jan 8, 2006 | 06:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Only time I ever saw backfire from anything was when something was awry with the plug wires or timing.
Old Jan 8, 2006 | 09:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have a strong spark? Are the injectors pulsing and giving fuel? Do you hear the pump come on while your cranking?
Old Jan 8, 2006 | 10:43 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
NOT TBI question, IS general tech question, MOVED
Old Jan 9, 2006 | 01:55 AM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Sorry it was in the wrong forum. Thanks for moving. It has good spark and the injectors are putting out plenty of fuel. Fuel pump is coming on. I am still mystified.
Old Jan 9, 2006 | 02:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
And your fuel pressure is....?
Spark color (on all 8 cylinders) is.....?
Old Jan 9, 2006 | 02:14 AM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
13 psi
Old Jan 9, 2006 | 07:15 AM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
re:stalling
the back fire sounds like the timing gear may have stripped.does the engine spin over really fast ,or alot faster than usual?IF you havent pulled the distributor,have someone help line up the timing mark on balancer with timing scale on front cover,then lift dist cap.rotor should be pointing to #1or#6 wire location.if not theres your prob.hope this helps jimmy
Old Jan 14, 2006 | 02:46 PM
jl112799's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Engine cranks normally.
Old Jan 15, 2006 | 12:17 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Backfire through the TBI usually means the spark is getting to the fuel when the intake valve is open. Sounds like a timing problem. Have you checked the inside of your dist. cap? and rotor? Other problems may be,
timing chain, dist. gear, module, cam, BAD vacuum leak.
I've had a problem like your's and it was the dist. gear. Allthough it never restarted again till I replaced the dist.
The only time it might try to restart is when the timing chain slips a tooth and causes a backfire like you mentioned.
Glowsock
Jul 24, 2025 03:15 PM
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
drathaar907
Aug 6, 2015 04:20 PM
