Running Rich
Old Jan 12, 2006 | 10:23 AM
MarkMueller's Avatar
Running Rich
89 4.3l TBI
Just had the motor rebuilt(bored 060 over). The motor is now running really rich. Rich enough that the plugs are wet and a dark brown in color(repalced plugs and wires same). Replaced the injectors recently no help. Base timing properly set to 0*. Have not checked the fuel pressure yet(renting a tool today). Vacuum check shows 21-20 in. bounces to indicate rich running engine. Once warm idles horrible but drives ok. Did a run on winaldl and it verifies rich. Anyone willing to take a look at the data and offer any advice would be appreciated. Already learned alot from searching on this forum. Once this engine is running better plan on some DIY prom work.
Also I have not yet set the minimum idle air. Should I replace anything before doing that? If I give the engine a vacuum leak it will lean out nicely(obviously).
http://nodial.net/onthego/20060111_173024_LOG.xls
Thanks,
MArk
Old Jan 12, 2006 | 01:25 PM
Fuel pressure @12.5 spec 9-13.
Old Jan 12, 2006 | 08:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
What does the coolant temp and TPS read on your scanner?
Also you might have a bad O2
Old Jan 13, 2006 | 08:39 AM
Collant temp gets up to 90.2 *c ~ 194*F
TPS @ idle around 1.2- 1.7 % open.
I think I am going to go ahead and change O2 sensor today.
Thanks,
MArk
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
