88 305 starter
Old Jan 31, 2006 | 05:00 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
88 305 starter
How hard is it to swap out the starter on an 88 convert 305 tbi?Looks like you remove a metal cover then the two bolts to the starter and it should drop down. Any advice.
Old Jan 31, 2006 | 06:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
disconnect the negative on the battery first, otherwise you're working with hot wiring, and you could weld your wrench onto the starter.... (guess how I know that?)
other then that you're fine.
Old Jan 31, 2006 | 06:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
(At least in the old days) starters had to be shimmed on installation - follow the directions with the starter to shim it to proper clearances - otherwise your getting too much or too little starter teeth in contact with the flywheel, and could break the flywheel. It's not hard to do, not to scare you, just a reminder that it is (or used to be in the old days) important.
Old Jan 31, 2006 | 08:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Clearances should be checked anyways and shimmed as needed anyway.
Old Mar 27, 2006 | 11:15 AM
88ragtop's Avatar
Engine: 305 tb
Transmission: auto
No one mentioned it takes a freaking hour to get the starter out of it's tight space after all wires and bolts are undone.
Old Mar 27, 2006 | 11:22 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
It IS possible to get the starter down from above the Y-Pipe, but its going to take some finesse. That is probably the hardest part. All you do is disconnect the negative battery cable, take off the wires from the starter that are attached to it (remember their order, idk if it matters but just be safe), drop out two bolts, take out starter...DONT DROP IT ON YOUR FACE! These things are an easy 20lbs and WILL do some damage. The installation is the reverse process, just be mindful of the shimming. Start it up and check to see if it works, be quick to shut her off if something doesnt seem right though. My issue was that the gear from the starter was too FAR from the flywheel...basically it needed to be REVERSE shimmed, meaning there was just a flaw in the design of it. I had to take it out, return it, and put the new one in. That one worked fine.
These shouldn't be too much either. My AC Delco starter was 15$ after a Core trade in of my old one, which had a value of 15$. Autozone will hook you up.
Good luck man.
Old Apr 3, 2006 | 01:51 PM
88ragtop's Avatar
Engine: 305 tb
Transmission: auto
Help guys. Been trying for hours and can't get the new starter back in above the y pipe. If I loosing the two nuts at the y pipe (connector just above the starter) will it drop down a little bit? Or will doing this cause a big exhaust leak when I go to tighting them up after the starter is in?
Old Apr 3, 2006 | 06:53 PM
You SHOULD be able to squeeze it in there, I did it with a 3" aftermarket pipe. If not, yes, you can unbolt the ypipe from the exhaust manifold, and that should give you some clearance. Just make sure you dont break those bolts off, they are probably rusted and **** from being so old, so use some PB Blaster if need be.
mhatfield 14
Oct 24, 2015 07:48 AM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
5spdcamaro
Aug 28, 2015 02:12 AM
