v6 Redline
Old Jan 31, 2006 | 07:09 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
v6 Redline
I have gone through a few clusters and am not sure if the cluster i have is origanal. I have a 1988, with a manual transmission and the 2.8 engine. What is the redline and the highest mpg read on the original cluster? Now sure what was original... Thanks!!!
Old Jan 31, 2006 | 08:22 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
redline is 6000rpm
Old Feb 1, 2006 | 10:42 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
the original 88 cluster shouldnt tell you the highest mpg...(maybe berlinetta?) The tach goes up to 7000 but the redline is 6k
2 big gauges, tach on the right speedo on left, tach has lil oil pressure gauge on the lower right of it, then 3 small gauges for batt, gas and temp in the middle of the 2 big ones.
Kinda sounds like you got an older third gen cluster, my friend's 82 has one that sounds like that.
Old Feb 4, 2006 | 11:28 AM
Car: 1988 Camaro SC
Engine: 2.8v6
yeah i meant Miles Per hour. My original said 115 i think, the one now has 85. The way you described is how mines is...
HikoriYami
Sep 21, 2015 07:11 PM
brharris27370
Dec 6, 2003 09:58 AM
vadrad
May 26, 2001 07:01 PM
matty350TPI
Aftermarket Product Review
Nov 19, 2000 06:41 PM
matty350TPI
