spark plugs cold/hot
Old Jan 31, 2006 | 10:33 PM
GMguy's Avatar
Car: 96camaro ss,87z28, elcamino,68 firebird
Engine: which car ?
Transmission: most likely a manuel
hey every one ,
i have a few questions about spark plugs .
1. i am working on a 350 in a 84 camaro for a friend an theres a cly thats burning oil an i would like to change the plug to a hotter pulg .
2. higher the # hotter the plug ?
3. higher compression an bigger cam do u need a colder plug ?
4.when do u need to change plugs colder/hotter when doing mods?
5.an if u have efi do u still need to change plugs due to mods or will the efi compensate for this ?
Old Feb 1, 2006 | 04:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
hot plug for a cold (tame) engine, cold plug for a hot (high perf) engine.
Has the engine been modified? Has the CR changed from stock?
Old Feb 2, 2006 | 08:52 AM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
You need to read the plugs. If increased compression creates detonation then you will need a colder plug. EFI cars need colder plugs if the mod creates detonation.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
