wont start
Old Feb 5, 2006 | 05:50 PM
87firebird50's Avatar
Car: Firebird
Engine: 5.0L
Transmission: auto
wont start
ok so the bird wont startafter i did the intake gaskets, and i made sure to get the timing as close as i could, but if the timing is off even a couple degrees would it not start???
Old Feb 5, 2006 | 08:03 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Couple of degrees? Nope it would still start.
Uhhhm....check for a bad/misaligned gasket, causing a massive vacuum leak?
Old Feb 5, 2006 | 11:34 PM
Car: Firebird
Engine: 5.0L
Transmission: auto
checked that, i think something in the dizzy is messed up..
Old Feb 6, 2006 | 12:16 AM
Car: Firebird
Engine: 5.0L
Transmission: auto
ok i checked to see if i was getting spark from the coil, im getting spark, i havent checked the spark comming from the cap yet though, i dont see how it wouldnt work i started it to make sure everything was still good before i did everything, i just dont get it..
Old Feb 6, 2006 | 02:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Before you pulled the dizzy did you note which cylinder the rotor was pointing to? Or did you just blindly pull it/restab it?
Old Feb 6, 2006 | 03:41 PM
Nixon1's Avatar
If the motor was turned over, which I doubt it was but you never know...maybe youre 180 out?
Old Feb 7, 2006 | 10:35 PM
Car: Firebird
Engine: 5.0L
Transmission: auto
ok i think i figured it out, i tried to start it with a weak battery, and so i flooded it and then so yesterday i get it to start and it starts right up with a jump runs rough but then i took it for a drive after i changed the spindle and then the motor just goes wide open, when i get it home the intake was leakin again, but i look at it today and i see i guess i cracked the intake so now im SOL and i think the carb is about to take a **** so, does anyone have an Intake/Carb for cheap or know of an aftermarket kit that is cheap that will work on it, i only need it to last about 4 months(brothers going to the marines)
Old Feb 7, 2006 | 10:37 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
intake crack? sounds like a job for jb weld.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
