Check Engine Light mystery
Old Feb 9, 2006 | 12:38 AM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
My light wont turn off. My computer reads a code 42 (faulty ingition module). My module must be fine since I can start my car. It can't be the computer because its reading codes. Also each wire going to the computer was tested for any shorts, and there fine. So can anyone tell me whats with my check engine light in my 83 Trans-Am
Old Feb 9, 2006 | 12:57 AM
stitchop's Avatar
Car: 91 firebird
The fact that your car will start does not mean the ingition module is fine. It can be faulty and still run.
Old Feb 9, 2006 | 01:03 AM
magadith's Avatar
Engine: 305 4bbl
I also tried 2 diffrent igniton modules (both I pocked from a junkyard) and still the same reading.
Old Feb 9, 2006 | 01:16 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you reset the ECM memory at all to see if it actually a current code?
Old Feb 9, 2006 | 01:29 PM
magadith's Avatar
Engine: 305 4bbl
How do you reset it?
Old Feb 9, 2006 | 01:30 PM
Synful's Avatar
disconnect the battery for about 30 seconds
Old Feb 9, 2006 | 02:29 PM
magadith's Avatar
Engine: 305 4bbl
Then thats not the problem. My cars battery has been dissconected for a while as I have been doing other work to it. It gets reconected when I run the engine for a few minutes as it sits.
Old Feb 9, 2006 | 05:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Go get your modules tested, just because it's running does not mean it is running right. Don't make it any harder than it has to be.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
