LT4 Hot Cam Users
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
LT4 Hot Cam Users
I need your guy's opinion. I'm doing a cam swap soon, and an HSR swap in the summertime.
First off, can you run a Hot Cam with the stock l98 heads, or is machining required to get valve clearance? What kind of gains have you guys seen with your Hot Cam swaps?
Second, would this be a nice cam to compliment the HSR intake along with some porting work on my stock L98 heads?
ttt, cmon guys, I know there are a bunch of you running an LT4 Hot Cam. I just need your opinions for my application.
Thanks for the info.
Can anyone else add to this or confirm this?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Cam
It'll work with it just not well, there are better choices out there.
But no, the cam won't work on those heads unless you do some machining.
What sort of numbers would you recommend for a cam for a 350 that will have an HSR by the summer time and a chip burnt with stock (ported) L98 heads?
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I have the GM LT4 HOT cam in my L98 with the stock torque converter and it works fine. I kept the stock torque converter since it's my daily driver. It idles at around 650-700 rpm. It took some tuning with the fuel curve to get the idle. I think I can get it to idle smoother and lower (maybe 600) if and when I get the spark advance tuned better. I didn't want to go with a higher-stall TC in order to keep the civilized daily-driver manners in stop-and-go traffic and trying to optimize fuel consumption while achieving a streetably-awesome hi-perf output level.
Car: 1983 G20 Chevy
Transmission: 4L60
I have a similar cam in my 305 TBI. Worked just fine with the stock 2,000 stall. I went to a 2,800 rpm stall for more punch, I still have the lockup for cruising.
LT1Formula
Aug 20, 2015 09:36 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
