L98 Alum. heads...what headgaskets?
Old Feb 11, 2006 | 01:28 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
I have a pair of aluminum heads off of a corvette and i was wondering if i can use a steel shim for headgaskets or do i have to use the factory head gaskets? and i am wondering what head bolts i can use? can i use my cast iron head bolts or do i have to buy new ones? i know with most alum head applications they recomend you buying new headbolts but i like to know what the story is.
Old Feb 12, 2006 | 01:51 PM
Car: 85 Camaro Z-28
Engine: 6.6
anyone?
Old Feb 12, 2006 | 01:56 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Not sure about the head gaskets, but you should use new head bolts with the machined flat washers needed for aluminum heads.
Old Feb 12, 2006 | 02:01 PM
Car: 85 Camaro Z-28
Engine: 6.6
yeah i used arp head bolts w/ washers with my edelbrock rpm heads...... and i used stock headgaskets for a regular cast iron head SBC
Old Feb 12, 2006 | 02:09 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A thin steel shim head gasket can be used with a aluminum head but you may get some galvanatic action ( corrosion) between the head and block because of the electrolitic action of the disssimular metals. It takes a long time for this corrosion to happen. Same as the water port openings will corrode over time on a aluminum manifold and steel heads.
using good antifreeze with corrosion additives or some "Water Wetter" in the cooling system will help a lot too.
If you're going to use a thicker composite gasket get on designed to not "brinnell" the aluminum head surface. (indent the head) (softer preflattened copper fire ring).
Reguardless of which gasket retorque the head bolts after a few warm up cycles. the head bolts will need hardened washers under the heads of each bolt.
Old Feb 12, 2006 | 02:14 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Use the stock GM .038 gasket or the performance GM .028 gasket to boost compression.
Old Feb 13, 2006 | 11:11 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
aluminum expands more than steel does when it gets hot, but then it cools faster than steel does. You'll be getting a lot of shearing of the gasket. it's best to use a standard OEM style FelPro gasket. You could try your luck with a steel shim gasket but as mentioned about the galvanic action, you might get rust that glues the head to the block
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
