Poor Man's alternative to Vacuum Canister/Pump?
Old Feb 11, 2006 | 11:26 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Don't flame me for this; it's just a thought. The AIR pump works as a vacuum pump to pull air from the manifolds and send it back into the engine, right? So, for somebody who isn't using it, would it function as a vacuum pump for an engine with a large cam? Another thought is whether the charcoal canister would work as a reservoir? If I'm an idiot, somebody just say so, but I'm curious if either of these things would work.
Old Feb 11, 2006 | 11:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1st question: You can use the A.I.R. pump as a crankcase vacuum pump.
2nd question: The charcoal canister isn't a tank, it's a charcoal-filled vent.
Old Feb 11, 2006 | 11:45 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am not plauged with the problem of low-vacuum for power brakes. I run hydroboost! Master cylinder, hoses, and booster from an early 90s diesel chevy van and a P/S pump from a 95 astro.
Old Feb 12, 2006 | 12:07 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I had considered doing a hydroboost, but a vacuum canister seems much easier. I think my neighbor has some old detroit diesel parts laying around, and I have been toying with the notion of going with a hydroboost.
Old Feb 12, 2006 | 12:12 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
All I can say, is that I have driven many different astro's and safari's over the years working in shops. The hydroboost assisted ones can output some serious pedal pressure compared to the vacuum units. We are allowed 25 feet from 20 mph here in Texas for inspections. I tromp the brakes when doing the braking tests, hydroboost assisted vehicles just stop better. They are a little noisier and wierder feeling, but they work well.
Old Feb 12, 2006 | 12:23 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I've go an 02 (gulp) Mustang GT as my daily, and interestingly, Ford used a hydroboost in those as well.
Old Feb 12, 2006 | 09:49 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm the first to try and rig something in order to save a buck - but I have to ask - Why all the trouble when a vacuum canister designed to hold vacuum for this reason can be had for $40?
Old Feb 12, 2006 | 10:04 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I'm not planning on doing it. My dad suggested it, and he is the type who would do that, so I told him I'd try to find out if it was possible. It is an interesting thought.
Pac J
May 17, 2020 10:44 AM
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
