Bolting Coil Bracket onto Intake Bolts????
Old Feb 16, 2006 | 11:19 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a 1991 z28 that had the TPI and now has a stealthram. i would like to mount my coil using the two center intake bolts on the passenger side...
can i remove those two center bolts (intake has already been bolted on), bolt on the coil bracket, and have everything hold up and seal correctly?]
TIA
Old Feb 16, 2006 | 11:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Some heads have the accessory holes drilled in both ends of the heads... why not use one of those holes on the back of the head (if its there)?
Old Feb 16, 2006 | 11:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
its too tight in the back of the motor and i dont want to run it in the front.
the factory bracket is also at the perfect angle to mount on the two center intake bolts....like its calling me to do this. i can route the wiring behind the fuel rails so it wont bee too visible.
but the questiosn remains...can i pull the two middle bolts only and replace them without any leaking? or will i just have to try it?
Old Feb 17, 2006 | 12:19 AM
miami79's Avatar
Car: camaro
Engine: 377sb 400++hp
Transmission: tko 600
I havé taken off the lift mounts and put back the bolts without any leakage but that was on a performer rpm intake so im not sure.
Old Feb 17, 2006 | 11:53 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I've pulled those out and put them back in, no problem. just be sure that when you put those two back that you don't over-torque them causing warping of the intake-head flange. I also recommend you put teflon thread sealer, sometimes there's oil-wicking up the threads, maybe it's capillary action, anyways, teflon thread sealer solved that problem. it depends on the heads, whether those threads open upon into the valley and are exposed to oil splash. when you put those two bolts back, may be a good time to retorque all the bolts, in the right sequence.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Dialed_In
Aug 20, 2015 01:45 PM
