Distributor gear wearing badly
Car: 87Z
Engine: top secret
Transmission: top secret
My distributor keeps going through gears. The gear is wearing a lot on the bottom half of the teeth. Is it possible that the distributor is sitting too high? I have no problems setting it into place and the gears appear to mesh fine. Could it be that the hole on the intake was not machined to the proper height. I have also tried three different distributors with all three having the same result. Any way to measure this height with the intake on the engine. This engine is a GM crate motor with now approximately 3,000 miles.This engine has a flat tappet cam so I have pretty much ruled out cam walk. Also this engine has a standard oil pump. I have heard of the grinding or filing the housing to supply the gear with more oil but I want to make sure there is not a setup issue first. Peace out.
Car: 87Z
Engine: top secret
it turned easily with the long screw driver when I was aligning the oil pump shaft for the distributor install. also seemed fine when I primed the enigne.
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
edit..
So what you're saying is that a flat tappet cam has no chance of walking? Distributor gear wear is usually the first sign of cam walk.
eightsixseven
Dec 16, 2024 01:50 PM
ambainb
Apr 25, 2016 09:21 PM
