how to tell if i have a roller or non roller
Old Feb 20, 2006 | 04:11 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
im gonna be rebuilding my 350, but have no idea if its a roller or non roller, how can i tell?
the previous owner swapped in the 350, but has no idea what it came out of, he did say that the cam and heads were reused from the 305.
Old Feb 20, 2006 | 04:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Look at the tappets. If they have rollers on them, it's a roller. If they are flat, it's a flat.
What year is the engine? Is it a stocker?
Old Feb 20, 2006 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If he reused the cam from a 91, then it's a roller.
Old Feb 22, 2006 | 05:11 PM
Car: 82 El Camino
Engine: built 355
thanks for the help,
what is a tappet by the way?
Old Feb 22, 2006 | 05:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
a lifter
Old Feb 22, 2006 | 06:23 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
i think tappet is a old school term-but as sonix said its a lifter connected to the rocker arm by a push rod...youll have to remove the intake to see if its roller or flat...btw when i built my current eng. i went with a nonroller and i still dont know what i was thinking...but it makes good power any way so dont sweat it too much unless your gonna race competitivly....tao
Old Feb 22, 2006 | 06:37 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Don't have to remove intake, factory rollers require a much shorter pushrod (approx. 7.2 inches vs. 7.8 inches).
Old Feb 24, 2006 | 06:42 PM
Car: 82 El Camino
Engine: built 355
which is better to have, roller or non roller?
Old Feb 24, 2006 | 06:45 PM
naf's Avatar
naf
My vote is for roller. Less resistance, more horsepower. Downside: more expensive to retrofit a non-roller block.
Old Feb 25, 2006 | 09:35 AM
ljnowell's Avatar
Tappet isnt an old school term, its a technical term.
There is nothing wrong with a flat tappet setup, people have succesfully built massive amounts of HP around them for a long time.
Old Feb 25, 2006 | 10:55 AM
naf's Avatar
naf
I'm running a flat tappet myself, mainly due to the downside: it would cost me more to swap over. Although I've got a roller block, I'd still have to buy more expensive lifters, spider and dog bones to convert. Cams are a little more expensive too.
Nothing wrong with flat tappet. One day I will swap over though.
Old Feb 25, 2006 | 08:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At least you can look for used stock parts instead of buying new, unlike a retro roller setup.
Also with a roller if you decide to change cams all you need is a new cam.
Old Feb 25, 2006 | 09:16 PM
Vader's Avatar
Originally posted by deadhead1882
how to tell if i have a roller or non roller]
Remove one rocker cover, start the engine, and see if the push rods spin.
Old Feb 25, 2006 | 09:19 PM
naf's Avatar
naf
Yeah, I've already priced the TPI roller setup from the local cam/fb JY. It's on the list, but so many other things are too.
I'm also not so sure the benefit of a roller is all in reduced valve train friction. The increased ramp rates a roller allows require higher spring rates...
Old Feb 25, 2006 | 11:22 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Is there a way to tell by looking ar the outside of the motor? Casting numbers or something? Like if I was walking through a junk yard, or at a swap meet or something. Something that doesnt require taking it apart? Thanks.
Old Feb 25, 2006 | 11:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Casting numbers will tell you if it's a roller block, but not necessarily that it has a roller cam.
Old Mar 11, 2006 | 10:36 AM
Car: 82 El Camino
Engine: built 355
if i use roller rockers will i need to switch to taller valve covers?
Old Mar 11, 2006 | 12:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Maybe... some need taller ones, some do not. Its kinda hot-or-miss with roller rockers.
Old Mar 11, 2006 | 01:21 PM
Car: 82 El Camino
Engine: built 355
ive got a set of edelbrock covers, and am planning on using summit 1.6 roller rockers, on stock heads.
anyone else using those covers with 1.6 roller rockers
Old Mar 12, 2006 | 01:07 AM
Air_Adam's Avatar
Tall or std height? Aluminum or steel valve covers? What rockers?
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
