92 350 Lifter Valley ?
Old Feb 22, 2006 | 09:30 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
ok this is my first post 86 motor build so be gentle. just obtained a 92 350 tpi motor less tpi. motor will be carbed. this is the first time being in a hyd roller block. not sure whats missing ? there are 3 bolt holes down the middle of the lifter valley, what are they for ? (valley pan) ? is there suppose to be any thing else associated with the lifters or do they just sit in there like old hyd lifters. if some one has pic of their build less intake or a detail drawing it would be appriciated. thanks.
Old Feb 22, 2006 | 09:32 AM
See this thread, there's a pic that will help
https://www.thirdgen.org/techbb2/sho...hreadid=343287
Old Feb 22, 2006 | 09:46 AM
SPIKE's Avatar
Car: 86 CAMARO
thanks sofa exactly what i was looking for. time to find the missing parts, should be able to buy all parts as kit with new lifters ? i hope.
Old Feb 22, 2006 | 10:26 AM
http://store.summitracing.com/partde...CA%2D08%2D1000
Or hit a junkyard
You'll need the lifters too; you can get those from a parts store, speed shop, etc. etc.
Old Feb 22, 2006 | 04:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Nice thing about factory hydraulic roller lifters is they don't have to be new. As long as they haven't been abused, they can be cleaned up and reused.
If you can't find all this stuff on the TGO classifieds, I would be shocked.
Old Feb 22, 2006 | 05:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have 85K on my lifters. I took them all apart and their was almost no buildup. A nice bath for them and they were all set. BUT I did find one lifter that had a crack from the bottom up to the roller wheel. I bought a new one for 6 bucks to replace that one.
Old Feb 22, 2006 | 08:10 PM
SPIKE's Avatar
Car: 86 CAMARO
thats my delima, motor was recently rebuilt with new cam that i want to reuse but half the lifters, hold down plate, push rods and those eyeglass looking things that hold lifters in place were gone. so yes im in search of lifters and all that stuff. is it allright to use used roller lifters with used cam even though they werent used together? or just get new lifters ? i was planning on spending most of my cash on heads but that will be a whole new thread
Old Feb 22, 2006 | 08:32 PM
91Z28-350's Avatar
Yes, as long as the lifters are in good shape. The lifters and cam don't need to be broken in together, as with flat tappet.
Old Feb 23, 2006 | 01:43 AM
Vader's Avatar
FWIW - In case you're hunting, those "eyeglass looking things" are often referred to as "dogbones" and the spring that retains them is called a "spider". That's not factory nomenclature, but what the aftermarket has frequently called them.
Using old rollers is just fine so long as the rollers are intact and axles are not worn.
Old Feb 23, 2006 | 02:23 PM
SPIKE's Avatar
Car: 86 CAMARO
thanks vader. a dogbone an a spider huntin i will go
Stryker412
Sep 7, 2015 09:11 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
z28guy134
Sep 1, 2015 11:50 PM
