cam question
Old Feb 22, 2006 | 07:57 PM
djtricia's Avatar
Car: 1986 Z-28
cam question
I have a comp roller cam #08-300-8 made for a computer controlled car. Specs @.050 lift, 450/480 lift at the valve, 208* duration, 112 LSA. My question is can this be used with a performer manifold and edelbrock 600 carb, 187 heads ported and polished on a 350? Trans is a 700r4 and will be using 3:42 gears in the rear.
Thanks.
Old Feb 22, 2006 | 08:03 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
that cam would be quite a good upgrade from the stock peanut ones the '86 models came with. You will want a decent flowing exhaust if you don't have one as yet....those heads and stock exhaust will hold you back a bit though so address those issues.
Old Feb 22, 2006 | 08:11 PM
djtricia's Avatar
Car: 1986 Z-28
cam
I have headers into a 3" exhaust pipe going back to a flowmaster and dual tail pipes.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
