305 qwestion
Nothing wrong with the ones that are on it.... assuming of course that there's nothing wrong with them.
Seriously, the castings you should have (081) are entirely adequate for that power level; assuming of course that it will be carbed.
I'd suggest nitrous then.
I have no other suggestions as to how to get that much power out of a 305 that's limited to TPI. I can make a few suggestions on how to get some more power out of it; but 300 HP is not bloody likely.
If your goal is 300 HP, that's relatively easy to do with a 350; and increasing the bore by changing the block probably would be about the cheapest way to take what you've got, to 300 HP.
350 HP out of a carbed 400 is almost unavoidable. I would be embarrassed to build a carbed 400 and not get that out of it. I don't think I'd even admit that if it ever happened, not even to my closest friends.
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
anything but a 283, 305, 307 better have over 300 if your building it, and those can all have 300 with very little effort
