compression
Old Feb 23, 2006 | 02:34 AM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
compression
i dont know if you can do this without the motor complete but but i put a compression tester on a couple of the cylinders and turned it over by hand and they all read 0 can you do a test with the block like this or not. its a 350 .30 over new pistons and rings and the rings are lined up right. hope this isnt a stupid question
Old Feb 23, 2006 | 02:40 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Are all the rocker arms adjusted properly? A 0 psi reading on the compression guage indicated the valves are open all the time. (rockers set too tight)
Old Feb 23, 2006 | 03:26 AM
Car: 1987 iroc z
nope that wasent it i can sorta hear it leaking from the bottom end could it be beacuse the rings havent seated yet but its weird how its 0 and its hard to turn over on the compression stroke so there has to be somthing.
Old Feb 23, 2006 | 11:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put the flexplate and starter on and try again.
Old Feb 23, 2006 | 11:07 AM
five7kid's Avatar
Actually, I'd think I'd want oil circulating before doing that.
Roller or flat tappet lifters?
Old Feb 23, 2006 | 11:27 AM
stitchop's Avatar
Car: 91 firebird
The air will leak out the ring gaps almost as fast as you can turn it by hand, that is the sound you hear from the bottem. You need a starter and and a good battery on it to turn it fast enough to test the compression.
Old Feb 23, 2006 | 12:38 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If it isn't a factory roller engine you'll have to retro-fit with an aftermarket kit for about a little under $1000 the lifters alone are $570 from Compcams.
I prime the oil pump with a drill motor and use 2 batteries in parallel to test compression, this is the way I fired up non-ECM motors before dropiing them in.
Old Feb 23, 2006 | 01:52 PM
five7kid's Avatar
Actually, my lifter question had more to do with cam break-in than performance. As in, if flat tappet, I don't think I'd dink around with this compression test on the stand.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
