need to order fuel filter, what size?
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
im bout to order a replacement fuel filter from summit, but they couldnt tell me what size thread the fitting is in the stick fuel line, and i couldnt find it in my service manual. which fuel filter do i need for stock gta TPI fuel lines?
so im not likely to see any improvement with a more expensive fuel filter with a replaceable element? i have a 255 lph granatelli fuel pump, 24lb injectors and 48 psi fuel pressure.
just head down to autozone and get the delco part?
pardon the blasphemy, advance auto i meant.
are the nice race ones from summit for 600+ hp motors only? mines ~375 at the wheels without spray, need to step up to some 30 lb injectors.
Car: '88 IROC-Z medium orange metallic
The bottleneck of the fuel system is the fuel lines, they will be too small waaaay before you reach the limit of the filter. I would be considering an upgrade, my 430hp motor sucked the stock rubber lines shut. Luckily I have a wideband 02 so I saw it go lean. That's when I made a new pickup in the tank and ran -8an from the pump to the engine.
stock lines are rubber? i just glanced under the car, but i coulda swore they were metal. or is it just metal over rubber?
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
