Valve Cover Sizes
Old Feb 28, 2006 | 12:16 PM
IROCRIDER's Avatar
Car: 85 CAMARO
Axle/Gears: Richmond 3.73's
Valve Cover Sizes
Hey guys how's it going? First post here kinda newbie, but here it goes. I had smoke coming from my engine, tracked it down to a leaky valve cover spilling onto exhaust. Well I go to changing the gaskets with rubber ones. After cleaning the block and covers of the old cork type gasket, I went to install the valve covers. Well the oil baffle broke off inside and doesn't go back together.
So I was wondering about getting some cheap chrome valve covers off Ebay. They are either 2 5/8 or 3 5/8 size. Anyone know the right size I should get? I'm thinking the 3 5/8 bigger styles one. Thanks in advance.
Old Feb 28, 2006 | 12:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
what year car? you can just get the regular valve covers, the tall size is typically for more rocker clearance for aftermarket rockers
Old Feb 28, 2006 | 12:44 PM
IROCRIDER's Avatar
Car: 85 CAMARO
Oh yeah that would help 1985 TPI motor all stock. Well thanks for the info I haven't changed the rockers so the smaller one makes sense now.
Old Feb 28, 2006 | 02:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
tpi motor means centerbolt valve covers doesn't it? just make sure on that one.
I went to taller valve covers, since they do no 'harm' that I know of, and if I do swap to a stud girdle, tall full roller rockers and polylocks, I don't have to go out and buy new valve covers again.
Old Feb 28, 2006 | 04:00 PM
xpndbl3's Avatar
Car: 1984 Z28
not necessarily. the 86 TPI wouldn't have centerbolt valve covers, since it would be 87-up that would have it.
Old Feb 28, 2006 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Taller valve covers can get in the way of accessories such as the AC compressor.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
