305tbi question
Old Feb 28, 2006 | 10:03 PM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
305tbi question
i have a 305 tbi i found to put into my 91rs that had a 3.1. my question is, does the 305 have anywhere close to the power that a tpi engine has? how many horses does the 305 have? i want a cruiser but also want to kick it down hard if needed to! also how does the infamous nos work with it? thanks all
Old Feb 28, 2006 | 10:08 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 305tbi question
I take it that you are a NewB, but that is OK. The L03 makes great low-mid range torque for what it is. They can be pretty quick when in a decent tune. A 5spd L03 with a good driver can take an automatic LB9 305 TPI with a bad driver. The L03s come with a crappy gear ratio though, chances are your 3.1 car has lower gears in it though.
NOS is a brand name not a part. Nitrous Oxide can be applied to any engine.
The L03 makes 170 FWHP @ 4,400 and 255 ft/lbs @ 2,800. With some simple, inexpensive mods you can push that to about 200 FWHP and 280 ft/lbs.
Old Feb 28, 2006 | 10:26 PM
Car: 1991 camaro rs
Engine: 3.1
ok! i'm not anewbie to camaro or engines jut the LO3! i used to own an 86 iroc with a 305 tpi also my cousin has the 350! i just was wondering how well the LO3's performed! also i know that nitrous oxide systems stands for "NOS" just always wanted to try it out! i don't think i will want alot maybe a 100 shot but i'm not sure if edelbrock makes a tbi 100 shot nitrous kit! oh yeah by the way should i get a wet or dry system?
Old Feb 28, 2006 | 10:30 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I'm sorry. Just thought this was another teenage kid post. Seems that most of them call nitrous, NOS and it just bugs me. A 100 HP WET shot would probably work fine, if you retarded the timing a few degrees.
Old Feb 28, 2006 | 10:40 PM
Car: 1991 camaro rs
Engine: 3.1
the LO3 has about 60000 so iwouldn't wanna go crazy on it but still wanna scream a little!!!! no offence taken man i was just explainin
Old Feb 28, 2006 | 10:45 PM
Car: 1991 camaro rs
Engine: 3.1
how much difference will i be a ble to notice with the lower v6 gears? that should help some with the performance!
Old Feb 28, 2006 | 10:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The lower gears are a speculation. I do know that my 2.8 GMC Jimmy had 3.73s in it. I think the V6 F-bodies of that time period came with around 3.23s instead of the typical 2.73 or 3.08:1 that the L03 came with. You will get a better launch with the lower gears provided you don't fry the tires. 3.08s to 3.73s in my Van dropped the 60' times by about two tenths.
Old Feb 28, 2006 | 10:58 PM
Car: 1991 camaro rs
Engine: 3.1
i understand! i have checked before and i do have the 3.23 gears!!
but since its an aoutomatic will that hurt me though? i have a bad leg or else i would have a 5 speed !!!! but oh well!!! shift kits are very easily abtained!
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
armybyrd
Aug 10, 2015 09:23 PM
