oil pan problem
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
OIL PAN PROBLEM ANY SUGESTIONS PLZ
hey guys i have a problem with a 1999 chevy silverado with a 4.3L
the oil pan is aluminum and it will not come off the damn engine all the bolts are out its just stuck there and i have pried on it with a bar and hit it with a 3pound hammer what should i do any suggestions plus that year gm put some kind of glue on both sides of the gaskets dumb idea
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Since this could be a problem with just about any vehicle, I would maybe use a metal scraper and try to tap it in between block and pan all around. Maybe heat the scraper up to melt any old RTV or gasket which was used.
Transmission: 4L80E/4L80E
Have you ever heard the saying, "If it seems too good to be true, it probably is"?
There's another saying, "If it seems like there's still a bolt holding it on, there probably is."
I know zip, nil, nada, about that engine. But, I'd say you need to look harder before you break something. It may be "glued", I really don't know.
The
part is, "3rd gen topics only, please." (It at least has to be 3rd gen relate-able.)
If someone reads this and knows the answer, they can PM you.
The
part is, "3rd gen topics only, please." (It at least has to be 3rd gen relate-able.)If someone reads this and knows the answer, they can PM you.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
