1.5 to 1.65
Old Mar 14, 2006 | 12:26 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
1.5 to 1.65
Looking into gettin Harland Sharp 1.65 rockers after I do heads (after shiftkit and rearend gears). My current cam has .465" lift and 224* duration (SUM-1104 summit), will putting those rockers on have any effect on the duration of my cam?
Old Mar 14, 2006 | 10:28 AM
91TPIFirechickn's Avatar
Car: 91 Formula
Engine: L98 TPI
Axle/Gears: 3:42 posi
Duration is ground into the cam and cannot be changed without changing the camshaft its self, all the rockers do is change the ammount of lift at the valve by various ratios (Eg. 1.65:1 or 1.5:1)
J
Old Mar 14, 2006 | 10:35 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Axle/Gears: MOSER 9IN 3.89
HI FIRECHICKEN, I thought that also but, to my supprise its does change the duration however small amount, the reason is it starts the lift process earlyer and ends it later, thus actually changing the duration. I read a large chapter on it in comp cams, about 2 years ago. Like I said though its not much but if your in a class that only lets you use limited cams every little bit helps. Also if your using 1.65 you may have to do some checking to make sure you dont have valve spring interferance, also coil bind, and piston to valve clearance issues.
Old Mar 14, 2006 | 11:13 AM
Car: 91 Formula
Engine: L98 TPI
that sounds supprising to me. I'm not saying that your wrong or that I am right but the camshaft lobe has a predetermined ammount of durration ground into it. the lifter follows that the same everytime which in turn acts upon the pushrod which in turn acts upon the rocker which changes the direction and the ratio to act upon the valve. its a translation of the cam profile it doesnt hold the valve open longer it just changes the ratio from cam to valve which determines how much the valve opens, but not how long its open(Duration). in order to change the duration the valve would have to be open longer which i dont see any way that a rocker arm itself can do.
the only way i see that it could act as if its changing in duration(Or give the appearance) is that it opens the valve more in comparion to the old ratio allowing for more air/fuel mixture into the cylinder and more exhaust gas out of the cylinder earlier on making more efficient use of the current cam profile.
just a thought
J
Old Mar 14, 2006 | 12:31 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well thnk about this most cams anymore are rated at .050" of lift for the start and end of duration.
with a higher ratio rocker arm your valve will reach that .050" of lift a little quicker then a lower ratio rocker arm. as the one guy said it won't change it by much but the fact remains it will still change the valve duration a little bit.
Old Mar 14, 2006 | 06:04 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Changing the rocker ratio does not change the cams duration. But it does increase the "running duration" at the valve. The effect is simular to adding about 2-3 degrees seat timing to the cam.
Changing the rocker ratio creates a subtle effect on the performance of a motor. For the $$$'s just change the camshaft to a differnt grind. Way more power to be had, for a lot less.
Old Mar 14, 2006 | 07:55 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Sorry FIRECHICKEN, Maybe I did not explaine it the right way, comp has an explanation that would make more sense. But the short of it is duration is expressed in crankshaft rotation and not the rotation of the cam, when in turn you change the duration by starting and slowing down the raise and lowering of the valve holding it off the seat for a longer amount of time during the rotation of the crankshaft. And F-BIRD was correct, I would also change the cam for more power instead of patching it with rocker arms, but if you dont have roller rockers now it would not hurt to get them, if your just looking to change the ratio I would do a cam swap instead.
Old Mar 14, 2006 | 07:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep the last couple of posts are correct. By the way "lift" is your friend for more horsepower if the heads can take it.
Old Mar 19, 2006 | 04:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Correct for the rocker arm, but the duration measurements are taken at .006" and .050" of lift AT THE LIFTER, not at the valve.
You are right when you say the valve will be at .050" lift sooner with 1.6 rockers, allowing more air into the engine sooner, but that still doesnt change the duration of the cam at .050", or the advertised duration at .006".
Old Mar 19, 2006 | 07:46 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
If you've got the engine down that far(head swapping),you can swap a much better grind in for around the same cash as swapping to 1.65 rockers.Not knocking your cam,but Summit's grinds,while a heck of a deal,are pretty outdated.
Old Mar 20, 2006 | 07:01 PM
ZEEYAA's Avatar
Car: 1991 Z-28
HI KEVIN91Z, I didnt think about it that way, I know your right about it not changing the cam duration, I was just going by what comp cam told me. But it does change when the action take place on the opening of the valve and therfore changes the effective duration and lift of the cam. But you are correct in that it does not effect the actual diminsions of the camshaft.
Old Mar 21, 2006 | 07:44 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ah didn't know it was at the lifter though it would make sense.
and in that case I would like to rephrase what I was saying.
it changes the EFFECTIVE duration of the cam or port.
not the real duration though
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IrocZ'85
Aug 17, 2015 06:24 PM
