How much to shave my heads?
Old Mar 20, 2006 | 11:51 AM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I have a set of 400 Heads that have 76cc Chambers and i want to get them down to 70cc's. How much do i shave the heads to get them down to 70cc's.
Old Mar 20, 2006 | 01:03 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I believe that the general rule is .006" for every 1cc. So .036" should do the trick. Why do you want to mill them? A better option the milling would be to start with some L98 or some 64cc 350 heads and port the chamber to your desired size.
Old Mar 20, 2006 | 01:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I agree with leigh, those heads you have (if stock heads) are probably junk, and not worth the price to mill them.
otherwise, i'd just leave the heads at your machine shop, and tell them to "mill the heads to 70cc's" and let them worry about the #'s.
Old Mar 20, 2006 | 03:06 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
I'm milling them for higher compression. The only reason i want to use these heads because they are in good shape and have 1.94 and 1.56 valves. I asked the guy at the machine shop how much to mill them and he says he cant cc the chambers so he didnt know.
Old Mar 20, 2006 | 03:40 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
If thats the case. You would be better off buying some 64cc chamber 350 heads that are in good shape. It will cost the same or maybe less if they don't need work. 400 heads are just about the worst out there.
Old Mar 20, 2006 | 05:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
...your machinist "can't" cc your heads? hmmm
Old Mar 20, 2006 | 10:01 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It's probably not a performance shop by any means. It's probably just your average, get it done as fast can low quality place.
Old Mar 20, 2006 | 11:24 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I have a set of center bolt iron l98 heads if your interested. Came off a remanufactured roller block 350 engine, a piston crack inside the engine when it was still under warranty and the owner sold it to me cheap. The heads are just sitting in my shop.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
madsv1000
Aug 20, 2015 06:45 AM
