Hood Padding, on or off?
Old Mar 23, 2006 | 01:32 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
What is your opinon about the underside of the hood having the foam padding...does it look better on or off?...does it have a function?
[IMG][/IMG]
Old Mar 23, 2006 | 04:05 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Dampens engine noise.
Old Mar 23, 2006 | 04:09 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I think the paint fades on the hood without it.
Old Mar 23, 2006 | 05:17 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I've heard (don't know how true it is) that in the event of an engine fire, the plastic "pins" that attach it to the hood melt, & the "padding" drops & is supposed to smother the fire.
Like I said, I don't know how true it is, but I've decided to leave mine on.
Old Mar 23, 2006 | 05:41 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Hood Foam
QUOTE (I've heard (don't know how true it is) that in the event of an engine fire, the plastic "pins" that attach it to the hood melt, & the "padding" drops & is supposed to smother the fire.)
Thats interesting, could be true...well, as long as there's no advantage of removing it, I guess I'll leave it be.
Old Mar 23, 2006 | 07:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its in good shape, so just leave it alone. Its not hurting anything. I took mine off, but only because it was all torn and furry-looking.
Old Mar 23, 2006 | 07:09 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
I think you should leave it on unless you plan on doing a wicked brust art on the inside of the hood :P
Old Mar 23, 2006 | 08:34 PM
Jza's Avatar
Jza
Get a new one if GM still makes them.. I ordered one from the dealership back in '00 or '01 and it was definitely a good investment. Makes an open hood look just great.
Old Mar 24, 2006 | 02:44 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
it is the truth, they are not "insulators" or sound dampners. these are fuctions that are sideffects.
That is your "fire blanket" in the even of a engine fire, it will fall.
Having it there will not suppress heat the hood is exposed to, it will just take longer for the heat to get there. I ran with mine off during the past winter, and at a red light, sure, there was "steam" coming from my hood, yet i didn't have a heater and was freezing.
I love hoods without them, they are much better when painted and all underneith as well...
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
