6.75 inch balancer, which one to buy
Old Mar 26, 2006 | 05:53 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I'm going to buy a new balancer, i'm just not sure if my engine is internally balanced, i'm almost positive it is. It's an 87 and up block with a stock crank rods and aftermarket pistons. I wanted to get peoples opinions on which balancer to buy. It' doesn't have to be sfi approved. thanks
Old Mar 27, 2006 | 08:32 AM
Damon's Avatar
Parts store replacement will do fine. Your engine is mostly internally balanced (flexplate/flywheel has a little counter-balancing on it, but not the balancer). No small block except the old 400 ever had a counter-balance weight on the balancer.
Old Mar 27, 2006 | 09:59 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
thanks, will do
Old Mar 27, 2006 | 10:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
probably want an 8" balancer for a 350. or else make sure your timing tab matches it.
Old Mar 27, 2006 | 10:59 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
It had this size on it, so i'm not going to change it. I didn't even know I could change the size with no dangerous affects.
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Old Mar 27, 2006 | 11:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, ok. usually that's the 305 size. whichever you like I guess, the timing tab would match it, so if it had a 6.75" one, then yea, might as well stick with it.
Old Mar 27, 2006 | 12:56 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I remember the guy at the machine shop telling me it was a 305 crank, which I didn't even know would fit into a 350 block. The person told me it was a stroker. I didn't know any better, it felt quick to me.
Old Mar 27, 2006 | 01:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
305 crank explains the 6.75" balancer. stroker is just...
Old Mar 27, 2006 | 05:30 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Yeah the cop that sold me the car told me it had a 383 stroker in it. But I guess you relly can't trust cops.
Old Mar 27, 2006 | 05:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, then finally i'll give an opinion, I got a summit brand non-sfi one, $59-61 depending on 6 3/4" or 8". It's basically a stock replacement, but has timing marks up to 60* BTDC, which is really handy, since I don't have a dial back timing light.
Old Mar 27, 2006 | 07:47 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I think my timing light has a dial back feature, I havne't even used it yet, I will have to read the book, thanks
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 8, 2015 11:28 PM
roysatikas
Sep 7, 2015 08:08 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
