Accel Header Spark Plugs
Old Mar 26, 2006 | 06:32 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well guys I just want to hear your opinions on this one. Will they make the car run bad? Do they help? How much do they cost? Anything you know or think about them would help me out alot. Trying to get the car back together after putting on headers.
Old Mar 26, 2006 | 07:07 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used them when I had on a pair of 416 heads and Hooker long tubes. They are really only for when you need extra clearence between a primary and a plug. They can be disassembled which is a plus. I like them.
Old Mar 26, 2006 | 07:11 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
i work in advance auto parts they are about 30 bucks for a set of 8
Old Mar 26, 2006 | 07:18 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
I hated them, i had three sets of them. Never could get the engine to run right with those plugs, then i said screw it and went out and bought some AC delcos. I will never buy a set of those overpriced plugs again.
Old Mar 26, 2006 | 07:22 PM
Engine: LB9, LB9
Well its looking like I am going to need that extra clearance, is there another kind of plug that would still make my car run like it has my AC delcos in it but provide that clearance?
Old Mar 26, 2006 | 08:40 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I've got em',they really don't give that much more clearence.I also have hooker long tubes,and I really think that if you ground on the tips a bit,you could fit a standard R43TS Delco in there,with a little patience.
I've not had any problems with the Accel shorties,but they cost twice what they are worth,and I'm not a big Accel fan to begin with.
Old Mar 26, 2006 | 09:27 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
I had them once, and I will never run them again. The terminals on the spark plugs on the end where the wire clips onto constantly came loose. All of them. Every saturday I had to take the plug wires off and tighten the terminals on the plugs. Got pretty annoying.
Old Mar 26, 2006 | 11:01 PM
jms's Avatar
jms
I used two sets of Accel plugs for header clearance.
Car really didn't like them.
Switched to AC.
Car is happy now.
One set of ACs lasted as long (actually longer) than the two sets of Accel.
jms
Old Mar 27, 2006 | 09:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Plain AC delco's are the way to go on a stock motor. If you are worried about clearance I would look into a modified spark plug socket.
Old Mar 27, 2006 | 10:00 AM
Tibo's Avatar
Car: 1991 Z28 Vert
People usually buy the shorties because there is no clearence between the spark plug boot and the primary.
If the plug "keeps coming apart" why wouldn't you use a dab of thread locker on it?
I do not believe that AC Delco's are a magic spark plug with the powers to make your car run good and that other plugs will use their powers to make your car run bad. It depends upon the heat range, elctrode length, gap, and material the plug is made of.
Old Mar 27, 2006 | 02:02 PM
Engine: LB9, LB9
I mean I need clearance between the plug and the boot.
Old Mar 27, 2006 | 06:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I think I got those plugs - but I got them for piston clearance, not header clearance - they were $30 a set from Advance and have shorter threads, thus they don't stick as far into the cylinder. The standard plugs I put in got all the ends bent from my pistons slapping them - I have dometops.
Old Mar 27, 2006 | 08:53 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
i am using autolite racing plugs. they are shorter and clear the headers well and cost about $23 a set. got them at advance. only thing is that they are tough to gap.
Old Mar 28, 2006 | 10:40 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
FYI the part # is AR133 for the 305
Old Mar 29, 2006 | 05:38 AM
Engine: LB9, LB9
Thanks alot bro.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
