Alternator question, pic inside
Old Mar 31, 2006 | 04:21 PM
NathanC5's Avatar
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
I couldn't really find the answer i was looking for in the forums so I took a picture. Anyway, my car is an 84 z28. I have a stock replacement alternator from oreillys. I have a question about the plug in the picture. Is it supposed to have a second wire? And if so where does this wire come from in the harness?
Old Mar 31, 2006 | 04:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I think mine has 2 on the plug, for some reason i think one was a jumper...
Ill check it out when i get home from work if nobody else has replied.
Old Mar 31, 2006 | 04:43 PM
NathanC5's Avatar
Car: 84 camaro z28
thanks, any help would be appreciated
Old Mar 31, 2006 | 05:27 PM
Yes there should be 2 wires. The one farther from the big post is the "sense" terminal, which is where the regulator samples the voltage that it's putting out, and adjusts its output accordingly. The one closer to the post is the "warning light" terminal, which needs a small amount of current flowing into it (specifically, about the amount of current that a light bulb passes, amazingly enough) to "start" the alternator charging. Without that wire, the alt will most likely never do anything.
The wire should be brown, and would come out of the harness next to the right valve cover.
See this post. About halfway down, Merlin scanned the page out of a factory service manual, with the schematic of that circuit.
https://www.thirdgen.org/forums/tech...verything.html
Last edited by sofakingdom; Mar 31, 2006 at 05:31 PM. Reason: Automerged Doublepost
Old Mar 31, 2006 | 06:17 PM
NathanC5's Avatar
Car: 84 camaro z28
would that affect my choke light or choke in anyway?
Old Mar 31, 2006 | 10:33 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The choke light is the alternator light (power flows through that light bulb and then to the terminal on that plug), so yes, it might be affecting the choke light.
Old Apr 2, 2006 | 06:21 PM
NathanC5's Avatar
Car: 84 camaro z28
ok, well i found the brown wire, but havent hooked it up. i have another question. the wire shown in the picture goes to the back of the alternator..is that correct?
Old Apr 2, 2006 | 06:25 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Yes
Old Apr 5, 2006 | 03:27 PM
NathanC5's Avatar
Car: 84 camaro z28
well i finally got it done. i bought a new alternator connector for about a buck fifty and spliced the brown wire to it. choke light was still on all the time. I was pretty sure my alternator was fine so i decided to go out and buy the choke relay. I pull down my convenience center and guess what? The choke relay was completely nonexistent. I put the relay in its place and everything is good. light comes on with key off but goes away when the car is on. perfect! thanks for all that chimed in.
Old Jun 23, 2006 | 10:11 PM
drmarc's Avatar
Car: 85 Trans Am
Engine: 305 4bbl
My choke light is now on whenever my car is off just after replacing the alternator.... Nathan makes that sound like its normal?? Whats going on PLEASE????
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
