Need some helpful imformation
Old Apr 3, 2006 | 12:07 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I was wondering what limitations a 350TPI engine has with only 25,000 miles. I would like to put a roller cam and make some other modifications down the road. I kno that i would need a bigger chip to go with the cam. I was wondering if I could expect to run into any "major" problems. Im also interested in buy a paxton or vortec supercharger. Any thoughts or suggestions? Also with these modifications the transmission and rear will be looked over and built stronger depending on the horsepower gains.
Old Apr 4, 2006 | 11:36 PM
Vader's Avatar
1. A 1988 SBC already has a roller cam;
2. A 1988 TPI has a MAF sensor, and changing a cam to something more aggressive doesn't necessarily require reprogramming ("bigger chip").
3. Installing an axial fan supercharger will require reprogramming, some new control components, additional fuel, timing retard, and would require that the cam profile be suitable for mild blower applications - The grind is significantly different.
Old Apr 5, 2006 | 07:22 AM
Car: 88 GTA, 74 T/A
Thanks for the info!
Hellbillydeluxe
Sep 22, 2015 09:58 PM
mdtoren
Aug 23, 2015 12:52 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Nj1987
Aug 19, 2015 08:26 PM
mdtoren
Aug 16, 2015 05:45 PM
