Wiper problem?
Old Apr 6, 2006 | 04:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Wiper problem?
Ok this is a weird one. Once in a while when I push the tab to spray water onto my windshield, the water just keeps coming out constantly for the normal time that it would normally come out in spurts (it does not do it the regular three times) and the wipers don't work. If the water is coming out and i turn the wipers on to clear some of the water, the wipers still don't come on. Only after it is done will the wipers work
This is only once in a while though. COuld it be the lever/turn signal that is going bad? Or could it be something else? Thanks in advance!
Old Apr 10, 2006 | 01:25 AM
Vader's Avatar
I'm thinking you're probably right. Check the switch/lever first. You should be able to get to it by removing only the lower side cover on the column.
Old Apr 10, 2006 | 01:27 AM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks, I think I'll just order a new one cause I hear it's pretty cheap. Just wanted a little more advice on this before i went on it though
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
