engine "loads" up
Old Apr 8, 2006 | 12:23 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
engine "loads" up
When i feather the peddle its fine. Then when i stand on it, it loads up, sorta liek its only fireing half the cylinders. When i let off the gas its fine. Im confused, my gfreind says itss bad spark plugs and wires.... any ideas?
Old Apr 8, 2006 | 12:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Could be flooding.
Old Apr 8, 2006 | 12:32 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
well it just happened recently so i have no idea. If it is floodinf how should i fix it. I knwo my air filter is dirty (oil leak on valve cover) im getting a new filter tomarrow. will that help the problem a little?
Old Apr 8, 2006 | 12:36 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
little problem?
sounds more ignition related to me...
spark plugs and wires are what i would do first. Timing might have come off a few degrees.
Old Apr 8, 2006 | 09:34 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
wont hurt anything if i drive it for this week? i doint get paid till friday
Old Apr 8, 2006 | 11:51 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
your pump shot might be a little off.
does it stumble and then catch up or just stumble and stay that way?
do you hear loud pinging or knocking noises?
what happens when you ease into WOT rather then just slam it into WOT? I know you said feather was fine just not sure how far you are feathering it or are you feathering to wide open?
take the plugs out floor it and watch it stumble then WHILE YOU STILL HAVE IT FLOORED turn the car off and coast to the side of the road. take plugs out and look at them. black, white, tan what color are they? also when doing this make sure to note once the car dies you will need to put the key back to on so the stearing wheel will allow you to turn rather then lock up. just make sure the car isn't in gear.
Old Apr 8, 2006 | 12:39 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
does it stumble and then catch up or just stumble and stay that way? stays styumbling
do you hear loud pinging or knocking noises? no
what happens when you ease into WOT rather then just slam it into WOT? I know you said feather was fine just not sure how far you are feathering it or are you feathering to wide open? stumbles and stays
Old Apr 8, 2006 | 05:35 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
can you clarify a little better. had a few questions asked each one and I'm lost as to how you are trying to explain it. sorry
Old Apr 8, 2006 | 08:30 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
When i floor it.. AKA WOT. its stumbles. It stumbles till i let off gas, and it doesnt cut off. Theres no ticking or knocking. When i ease into WOT it stills tumbles. I can keep the peddle off the floor, lets say 1/4" and its doesnt stumble. This problem doesnt bother me, becuase i dont WOT to often (gas, not into racing, etc. etc.) But its perplexing and i would like to get it fixed befor ei sell it..
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
