One tire sticks out farther than the other... HELP!
Old Apr 10, 2006 | 01:08 AM
CamaroRog's Avatar
Car: 91 RS
Engine: lo3 305 :(
Transmission: 700r-4
Axle/Gears: 3.42 - Torsen Posi
I changed my rear gears, and added a posi last weekend, and my friend pointed somthing out to me. My left tire sticks out from the fender about 2in farther than the right tire when viewed from behind. Its very obvious if you look at the bottom of each rear quarter and where it aligns on the tire from behind. I checked out the whole rear subframe and nothing appeared to be obviously bent or skewed. My right rear quarter is dented really badly but I dont think it warped the whole thing enought to make it look like the tire is sticking out farther. What could possibly be wrong? Could the entire subframe itself be warped? Could something else be really messed up? Or is that dented fender the only possible cause? Thanks in advance
Old Apr 10, 2006 | 01:47 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Err.. if the work was done right, then it's either been whacked real good to shift the rear over or the quarter isn't true. Start checking suspension geometry and you'll likely find the culprit.
Incidentally, I've had two GTAs that were off to the left a bit, but not 2" worth.
Old Apr 10, 2006 | 01:54 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Is it stock ride height? 'Cause dont forget if you lowered it too, if you dont get an adjustable panhard rod it'll do that.
Old Apr 10, 2006 | 09:55 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine does that. It's really noticable with big tires.
Old Apr 10, 2006 | 01:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
panhard rod. make sure it's in right, and you didn't leave it out or put it in wrong somehow.
if all is well, buy yourself (or make yourself) and adjustable one.
Old Apr 10, 2006 | 03:07 PM
CamaroRog's Avatar
Car: 91 RS
Engine: lo3 305 :(
Its lowered about 1 in in the front and lifted 3in in the rear. Would the lift and panhard rod cause it to do this. The panhard rod is the diagonal rod running across the rearend right. I am a fabricator so making an adjustable one wouldn't be to bad if this is the cause, can someone point me somewhere so i make it right? Someone who has made their own before maybe.
Old Apr 10, 2006 | 03:41 PM
305q_ta86's Avatar
Transmission: 5 spd
Yeah, that's teh panhard. And yeah lifting it 3" would do it. Try searching the fabbing forum for info. There has to be tons.
Old Apr 10, 2006 | 04:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
look at the adjustable ones made by the aftermarket (read: Spohn), a glance should let you know how it'll work. Give yourself 4" of adjustment and you should be fine. A chunk of 1/8" wall pipe/tube should work, with some threaded rod style adjustment in the middle or something. Maybe use rod ends instead of the bushing holes in the sides
Old Apr 10, 2006 | 05:08 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
do you have front/rear specific wheels? if you have a front and rear wheel on teh back i could see that possably hapening.
Old Apr 10, 2006 | 05:56 PM
CamaroRog's Avatar
Car: 91 RS
Engine: lo3 305 :(
umm ya I have rally tires but you would have to be a serious dumbass to mix them up lol. Plus the fronts havent been off in ages. Thanks evryone else...will be checking the fabbing forum and spohn.
Old Apr 10, 2006 | 09:22 PM
305q_ta86's Avatar
Transmission: 5 spd
Haha that's not what he meant. He was talking about the wheels where there are two for the front and two for the rear. And they are different wheels, not just different tires.
Old Apr 10, 2006 | 09:59 PM
CamaroRog's Avatar
Car: 91 RS
Engine: lo3 305 :(
umm yes my rims are different front to rear, we call them rally wheels/rims here idk if you have a different name for them. The front rim center is sunken about half as far as the rear. Hence why I said i could never mix the front/rears up since they have such a different appearance due to the rims.
Old Apr 10, 2006 | 11:44 PM
305q_ta86's Avatar
Transmission: 5 spd
Ok, that's all well and good, but you didnt say rally rims, you said rally tires.
Old Apr 11, 2006 | 08:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
A 2" shift on a 1" drop is excessive imnsho. I don't think the radius is that abrupt.
Old Apr 11, 2006 | 10:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It was a 2" shift on a 3" lift that did it!!!
He dropped the front 1"
Old Apr 11, 2006 | 10:45 PM
305q_ta86's Avatar
Transmission: 5 spd
Uh, guys. It's only a 1 inch shift. If it sticks out 2 inches more on one side, and you shifted it back 2", it would just stick out the same ammount on the other side.
Plus, if you're just talking about the panhard, since the angle is so small, a 2" shift on a 2" drop would be impossible anyway. A 1" shift on a 3" lift? Possible..?
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
84 TA NV
Sep 6, 2015 08:02 PM
