What does this tube do! do i need it?
Old Apr 11, 2006 | 11:21 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
This tube runs from the mysterious sphere to the brake booster device as shown in the photo...what does this tube do?....i wanted to remove the mysterious sphere and just plug the other end...can i do that?
[IMG][/IMG]
[IMG][/IMG]
Old Apr 11, 2006 | 11:29 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
I believe that is a vaccuum reserve canister. probably runs to the heater controls. provides a vacuum soruce so when the motor is floored, and essentially loses vacuum, your heat settings do not change. not really a neccesary componet, but not really hurting performance either.
Old Apr 11, 2006 | 11:37 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
right on the head, but it also helps to reserve vac for the brakes also
Old Apr 11, 2006 | 11:51 AM
Car: 1988 SC Camaro
Engine: 305 TBI
Old Apr 11, 2006 | 12:14 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yeah you might want to keep that. it's the reserve canister.
I about spit out my drink when I read "mysterious sphere."
Old Apr 11, 2006 | 12:31 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
"The globe of death" is what i usually hear it referred to as...
Reserve canister so you can still operate HVAC and other vacuume goodies when you go WOT when the engine is producing very little vacuume!
Old Apr 11, 2006 | 01:40 PM
Car: 91 RS
Engine: 5.0 tbi
it's the orb of power......and my 84 had 2.....lol.....m-pha-sis.....had. there was the one under the charchole canister(evap canister), and a brick on the firewall.......one was for brakes and all and the other for the meat/a/c control, but now all but the brakes are gone so lets see how the brakes work with the new motor though I might add the orb back in
Old Apr 11, 2006 | 04:30 PM
Car: 1988 SC Camaro
Engine: 305 TBI
So are you saying that at WOT, (if i have my heat blowing on its highest speed), that it will not blow as hard if i remove the orb of power?
Old Apr 11, 2006 | 04:41 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
It won't effect the fan speed.
Your environment controls are vaccum controlled, remove all vaccum and your heater plenium will deflect all air to the Windshield. So at WOT with no vaccum back up the air will go to the windshield.
Old Apr 11, 2006 | 05:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Exactly!
When vacuume is lost the HVAC automatically blows it all to the windshield for safety purposes.
Old Apr 11, 2006 | 06:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Also, if you have cruise control, that is a vacuum operated also
Old Apr 11, 2006 | 06:22 PM
Jza's Avatar
Jza
The most important thing is that it gives you one or two power-assisted pumps on the brakes if the engine cuts out so that you can stop. After that it's quad-powered (as in your thigh muscles).
You might notice if you're sitting there with the engine off and you move the HVAC selector you'll hear hissing and movement. That's the flaps being opened/closed actuated by the reserve vacuum. Eventually you won't be able to move it around anymore until you've run the car and built up some more vacuum.
Leave it in. The convenience far outweighs any benefits you'd get from removing it.
Old Apr 11, 2006 | 07:32 PM
Car: 1988 SC Camaro
Engine: 305 TBI
ohh, all right....I'll leave it in
Maybe you can help me asnswer something else....In this picture one of the tubes from that booster thing is missing...I remember taking it off but i can't find it now!...i know that sounds dumb, but its true...where does the tube on this end connnect to?...I can't find it, LOL!!!
[IMG][/IMG]
Old Apr 11, 2006 | 07:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Old Apr 11, 2006 | 07:54 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
lol i think someone's head is in the gutter lol
Old Apr 12, 2006 | 03:49 AM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
THE ORB OF POWER!!!!!!
Old Apr 12, 2006 | 07:13 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Any Ideas about where the hole/plug leads to (the ones thats denoted by the question mark). ITs missing right now and i can't find the hose, or even waht it connect to....ideas?
Old Apr 15, 2006 | 10:07 PM
Car: 91 RS
Engine: 5.0 tbi
well just start pullin at things and see whats loose
Old Apr 16, 2006 | 12:45 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Is their still a line running out of the back of the carb?
Thats typically where the brake booster pulls its vac...
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
