any idea what this is?
Old Apr 12, 2006 | 06:35 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I have a little canister bolted to the back of the drivers side head on my 86 berlinetta 305 4bbl rochester quadrajet it goes to the tach side of the distributor. What is this ?
Old Apr 15, 2006 | 07:48 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
doesen't anyone know what this is?
Old Apr 16, 2006 | 12:31 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
can you post a picture?
a capacitor of some sort? I've never seen that, that I can think of...
Old Apr 16, 2006 | 12:48 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Maybe it has a heavy duty truck engine in it? Seems like they had a Throttle Return Control module that is shaped like a matchbox on the driverside valve cover.
It is also possibly a condensor that has been added to help eliminate RF interference.
Old Apr 16, 2006 | 10:11 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I can't get a picture its in a place I can't get to with a camera I'll try to get it out and take a pic, but it's just a capacitor looking thing with wires on each end. Its going to the tach wire on the distributor. It may just be a capacitor. I don't know. I was hoping someone knew what it was. Its the original engine.
Old Apr 16, 2006 | 10:28 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Probably for tach related performance....ie calibration etc
Old Apr 16, 2006 | 10:33 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Ok, Thank you.
Old Apr 18, 2006 | 02:50 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's called a tachometer filter. I'm not sure what it actually filters - but that's what its called !!!
Old Apr 18, 2006 | 02:59 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Thank you.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
