EAGLE 383 rotating assembly
Old Apr 12, 2006 | 12:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
for about a grand in Summit Racing
it's cast- how far would you trust a cast 383?
Old Apr 12, 2006 | 12:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i seen those kits go for 450hp on motor in cars.. i think thats as high as i would go. i think cast cranks are usually fine for power, it just the rods and pistons that may fail.. so if you have strong rods and pistons, a cast crank should make lots of power
Old Apr 12, 2006 | 01:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Its a cast crank but not cast iron. It is made of some higher grade alloy. So it is much stronger than a stock cast crank.
Old Apr 12, 2006 | 01:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
cast alloy crank, forged I beams and hyper pistons?
Should be good to 450HP or more.
I figure the crank is worth ~$300, I beams $250, and pistons $200, if you bought them all seperate. So I'd hope their premium parts for that price, or you're getting more then just those parts.
balanced together?
Old Apr 12, 2006 | 05:48 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
balanced together?
They are balanced, yes. I want to avoid having to "get" them all balanced just because I hear thats expensive.
Old Apr 12, 2006 | 05:57 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
i bought all my parts separately.
crank $500 used(2 drag runs)
foged rods $250 new
Hyper Pistons $75 shipped(later upgraded to forged but they were $75 shipped)
Balancing $125 at the machine shop.
eagle is overpriced IMO...
My crank is also forged and nitrided....
balancing is cheap enough!
Old Apr 12, 2006 | 08:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
foged rods $250 new
How cheap?
What's more important? Forged pistons or rods? Crank is last from what I understand...
Old Apr 12, 2006 | 08:57 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I can't remember my total bill, but I can tell you it cost me $90 in heavy metal to have my kit internally balanced. I used TRW forged pistons, speedomotive 4340 forged rods (i beams), and eagle 4340 forged 400 externally balanced crank. It was still actually cheaper for me to buy the 400 crank, pay the $100 to have it cut to 350 mains and internally balanced at the time over buying one right from Jegs. Back then the prices were $600+ for the 383 4340 ESP cranks.
Old Apr 12, 2006 | 08:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'd take slugs over the rods - as long as good rod bolts are used.
Old Apr 12, 2006 | 11:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd have to look pretty hard to find a set of rods that aren't forged.
Old Apr 12, 2006 | 11:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
look into ohio crankshaft, their stuff is a really good deal. I think they can balance some stuff for you before sending it to you also.
remember, *cheap* forged pistons (ie truck stuff, or just any cheap brand forged pistons) are heavier, which is a bad thing, and if it means they have to use heavy metal when balancing, it's more $$$.
my machinist told me it was $300 to balance, if no heavy metal was needed. So I didn't.
Old Apr 13, 2006 | 12:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Heavy metal isn't always needed to balance heavier pistons. A new crank may already have heavy counterweights that can be drilled, or a used crank may already have balancing holes drilled that can be filled in with a steel slug.
Old Apr 13, 2006 | 01:04 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
If you are going to spend $1000 on a non forged bottom end you may want to look into the Engine kits from Doug Herbert. I went with the 383 pro -street kit. Scat nitrided 4340 forged crank, wiseco forged pistons, 4340 forged "I" beam rods, plasma-Moly rings and clevite77 bearings. For $1359 it seems to be a very strong kit. The extra $359 is good insurance and will give you piece of mind knowing you have a forged bottom end. IMO eagle is overpriced
Old Apr 13, 2006 | 01:51 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
the eagle kit also comes with a balancer, flexplate,rings and bearings for that price not too bad of a deal. i was considering gettin one for my T/A
Old Apr 13, 2006 | 04:32 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old Apr 14, 2006 | 11:55 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Eagle's site says that the crank is good to 500. I know its just a number, but balanced it should hold all of that, maybe more.
Old Apr 14, 2006 | 07:40 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
What do you want to do with the motor? How much compression are you going to run? If you're building a street/strip n/a pump gas motor with not a ton of compression you don't need to spend the money on forged pistons. Hypereutectics are just fine.
For what they are, Eagle kits and parts in general are priced very fair. They hold up very well.
Old Apr 14, 2006 | 10:12 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
My crank had already been balanced once before, i didn't get cheap forged pistons, for this reason, my 6.2in rod's were also a bit heavier. No heavymetal was needed for balancing if you do it all correctly.
as the saying goes
"cheap prices come to those who wait"
my engine swap parts pile started a year or more ago. EBAY IS YOUR FRIEND!!!!!!!!!!!!
I got my set of moly rings for $40.
Only the externally balanced kits come with flexplate and balancer.
86+ one piece rear main seals are externally balanced on the rear side.
383 kits come with flywheel and flexplate
85 and below dont however, notice the price difference!
Old Apr 14, 2006 | 10:17 PM
Dialed_In's Avatar
as the saying goes
And you get what you pay for.
Seems like everyone wants to save a buck, but when the car makes no power and runs 14's they want to blame it on the parts.
Old Apr 14, 2006 | 10:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run an Eagle Cast 383 Crank, Eagle H beams and Hyper pistons. been to 6700 a few times on the dyno with no problems and also put down some good numbers. Its how the engine is built and balanced that can also effect reliability.
Old Apr 14, 2006 | 10:40 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
take a wild guess what brand parts i have also.... you wont believe it, they were all boxed... except the crank, 2 drag runs...
i'll give ya a hint, speed pro powerfoged pistons, Eagle "esp" h beams, crank was something like a sledgehammer or something, most expensive item i bought...
all were great deals i couldn't pass up.
Last edited by 12SecondTA; Apr 14, 2006 at 10:44 PM. Reason: Automerged Doublepost
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
