Die and Tap - Metric or Standard?
Old Apr 13, 2006 | 06:40 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I'm looking to buy a die and tap set from summit. Theres a metric set and SAE (standard) set. Which do I want?
Old Apr 13, 2006 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Both
Old Apr 13, 2006 | 06:56 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
I was expectin that. THanks.
Old Apr 13, 2006 | 09:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Standard will be alot more useful for everyday use.
Old Apr 13, 2006 | 10:42 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I disagree, metric is much more common these days. If you choose one I would say metric, but ideally you should get both.
Old Apr 14, 2006 | 12:24 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I have standard and metric kits i have only used the metric kit once.
Old Apr 14, 2006 | 12:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're using your taps to clean threads, The engine uses mostly SAE fasteners. Nearly everything else on the car is metric.
If you're using them to cut new threads in parts you're fabricating, it probably doesn't matter that much which you use, as long as you can get fasteners to match.
Old Apr 14, 2006 | 02:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
get -AN !
Old Apr 14, 2006 | 10:41 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Im getting this for a just-in-case when I do header install, so I'll start off with SAE.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
