Drilling aluminum?
Old Apr 15, 2006 | 12:53 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Drilling aluminum?
I just bought these valve covers and as you can see,there are no oil cap or pcv provisions.How do I drill out the holes without ruining the covers?
Old Apr 15, 2006 | 12:58 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Holesaw for metal, and a drill press. A machine shop would be the best way though.
Old Apr 15, 2006 | 01:47 AM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
^^^what he said. you can also use your die grinder or dremel. Trace a circle the size of the hole you want, and grind it out to the line.
Old Apr 15, 2006 | 02:03 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
sweet,thanks.That's what I figured.
Old Apr 15, 2006 | 11:33 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Can you send those back. They make those covers with the proper holes in them already for the same price.
Old Apr 15, 2006 | 11:54 AM
82knightrider's Avatar
Transmission: TH200C....700R4
Theres some factory center bolt valve covers from a 92 TPI at the j/y right now.You should go buy them.They are very nice and clean
Old Apr 15, 2006 | 12:54 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
what's so grear about center bolt valve covers?
Old Apr 15, 2006 | 05:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They fit center bolt heads.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
